Page 4 of 10 FirstFirst 12345678 ... LastLast
Results 31 to 40 of 93
    Aug 2005
    #31
    Anybody using the Spy brand tpms?
    Sent from my SM-C900F using Tapatalk
    Oct 2017
    #32
    Hi i am planning to replace the tpms tire air with nitro. Any recommendation where is the best service place for this ? Yun marunong na talyer...thanks
    Sent from my SM-G950F using Tsikot Forums mobile app
    Jan 2019
    #33
    Thanks for the info.
    Jan 2020
    #34
    Quote Originally Posted by jedi View Post
    I will install this new Wireless TPMS to my car, before offering it to the public. There are internal and external sensors but i chose to get the external TPMS for DIY purposes. Internal sensors will also be available.
    Let me guide you on why TPMS is very important
    Protection in advance:TPMS directly monitors the Tire's pressure and temperature.when the tire show an abnormal sign,TPMS can Promptly notice the driver to do some corresponding measure to avoid accidents and ensure safety.
    Extend the tire’s life:when tire’s pressure is 10% pressure value under standard,the tire’s lifespan will reduce 15%.with in-time digital display of pressure and temperature value,TPMS can help driver to keep tire the standard pressure,so as to extend the tire’s life.
    Save Fuel consumption:when the tire’s pressure is 30% below standard,the fuel consumption increase 15%.TPMS can help drive to keep the tire’s standard pressure,cut fuel consumption.
    Protect automobile parts:if driving when the tire is not at the standard pressure(too high or too low),it will bring some abrasion to the engine chassis and suspended system.
    Guarantee the normally-operating Brake System:if the tire’s pressure is not in balance,it will make the vehicle run deviate in braking,so as to increase the accident risk.
    Monitor the tire in real time:TPMS can help driver control the tire condition easily at any moment in vehicle,so as to help drive to make right decision,and ensure safety.
    External TPMS
    Internal TPMS
    1.TPMS (Wireless-External sensors):
    a. Display
    b. cigar lighter charger
    c. external mounted sensor
    d. anti-thief nozzle
    2. Functions and Features
    Product Features
    (1) Real time monitoring tire pressure and temperature at the same time.
    (2) Display show pressure and temperature of 4 tires on screen.
    (3) Display show which tire is abnormal.
    (4) Powerful function include low pressure alarm, high pressure alarm, leakage alarm, high temperature alarm, low sensor battery alarm, low display battery alarm, signal missing alarm.
    (5) Alarm with beep sound and display screen red light flashing.
    (6) Sensor battery changeable.
    (7) Dual power supply of battery and charger.
    Alarm Function
    (1) Leakage alarm: The pressure decrease over 0.2Bar in 20 seconds
    (2) Low pressure alarm: The pressure is lower than standard about 25%
    (3) High Pressure Alarm: The pressure is higher than standard about 40%
    (4) High temperature alarm: The temperature of tire is over the threshold
    (5) Low power of sensor alarm: The power of any sensor is less than 2.4v
    (6) No signal alarm: Missing some sensors’ message over 25 minutes after it start to work
    Operating Functions
    (1) Pressure Unit setting: change Bar to PSI (pre-set unit is bar)
    (2) Temperature Unit setting : change °C to °F (pre-set unit is °C)
    (3) Standard pressure setting: increase or decrease (pre-set value is cold tire pressure 2.4 Bar)
    (4) High temperature alarm threshold setting: pre-set threshold is 80°C
    (5) Set up sensor: learn new sensor ID code when replace sensor
    (6) Exchange tires position: when mismatch sensor to tires, change position on display
    call me at 09053338777 , 09228335588, 3481728.. I am willing to give special price for the first few orders.
    There will be two models to choose from... Wireless External and Wireless Internal
    SRP: P11,000
    Advance Order: P9,000 for wireless or external TPMS
    This is important to have in the car
    Feb 2012
    #35
    SRP: P11,000
    Imagine, from 9,000 to almost 800.00 na lang. Salamat Shopee (at Lazada) talaga.
    Looking to try one set since madalas na bumababa ang tire pressure ng iba kong gulong.
    My only worry is wala kayang epekto sa tire balance ito? Or magaan lang siya?
    Sep 2016
    #36
    Quote Originally Posted by gearhead000 View Post
    Magaan lang sya. Ang gamit ko is yung external tapos USB yung bluetooth receiver. Sa android HU ko minomonitor yung tire pressure.
    Jul 2013
    #37
    gaano katagal battery life nya? and replaceable ba yung battery?
    Sep 2016
    #38
    May 2021 ko nabili yung akin. So far okay pa naman. CR1632 yung battery nya. May tool na kasama pangbukas ng sensor para mapalitan ang battery.
    #39
    Dati mahirap maghanap ng batt ng mga yan pero nowadays madami na sa mga hardware stores like ace, true value, & handyman.
    Btw, iyong mga solar powered tpms monitors niyo maganda pa ang charging? Iyong akin kung matagal naka shade medyo naghihingalo na. Pero pag naarawan ok nanaman [emoji16]
    Jan 2009
    #40
    In my case, there's tint between it and the glass so solar charging is not efficient. What I do is charge it using USB every couple of months or so pag nakita ko 1-2 bars nalang. Yung solar charging still works to some extent kasi it extends the battery capacity so madalang ko lang i-charge using USB.
Wireless  TPMS Tire Pressure Monitoring System
