Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 56
    #41
    Quote Originally Posted by NiCe2KnowU View Post
    Sayang eh may itatagal pa. Gilid Lang medyo napudpod dahil nag negative
    swap mo muna sa kabilang side bro
    tapos after couple of thousand km, inside out naman
    pero ako sa ganyan, if ok pa rear tires; replace both fronts tires nalang kung malaki na difference nun upod na part
    Sep 2013
    #42
    Baka palitan ko nalang 2 gulong na napudpod, Yung SA rear pwde pa Naman, pang city driving ko lang Naman tong extra car.
    Palitan ko nalang bago ako magpacamber alignment.
    Sep 2013
    #43
    Yung pinuntahan ko pinapalagay ako NG camber kit para mapantay, naka lowered kasi extra car ko.
    Makukuha Naman sa wheel alignment ng TOE para di mabilis mapudpod gilid NG gulong
    nakapunta nako shell c5 near mitsubishi ..
    gamit nila the hunter pa100 PA 130
    yun na ba yung ok na klase?
    550 alignment nila
    camber 1.6k (iirc)
    ok na yan, ang important tamang car selection sa program and right tire pressure. if any of the two are not accurate baka kelangan bumalik. sounds like you got ok results?
    #45
    inaantay ko muna go signal mo bro, nun pumunta ako naka lunchbreak din sila eh
    Jul 2012
    #46
    ok lang naka negative camber basta naka zero toe, ang malakas makaupod pag naka toe-in or toe-out dahil hindi naka-straight sa moving direction ang tires kaya may slight scrubbing
    Sep 2013
    #47
    Quote Originally Posted by enzo6k View Post
    Yes sur... Nag pa align nako last Saturday NG toe & caster / rear & front [emoji846]
    Oct 2011
    #48
    Try fixstop along congressional ave qc
    Sent from my STK-L22 using Tapatalk
    Dec 2023
    #49
    Interesting anecdote:
    If I ask an aligner to make my car go straight ahead, it pulls left when I go back out on the road.
    If I ask the aligner to make the car pull right, it rolls straight when I hit the road!
    #50
    nagapalit ako ng pang-ilalim kahapon so takbo ako magpa- alignment service maybe tomorrow.
    ang problema may slow leak ata ang isang gulong ko so kailangan patingin ko muna
Wheel Alignment
