Page 1 of 10 12345 ... LastLast
Results 1 to 10 of 93
    I will install this new Wireless TPMS to my car, before offering it to the public. There are internal and external sensors but i chose to get the external TPMS for DIY purposes. Internal sensors will also be available.
    Let me guide you on why TPMS is very important
    Protection in advance:TPMS directly monitors the Tire's pressure and temperature.when the tire show an abnormal sign,TPMS can Promptly notice the driver to do some corresponding measure to avoid accidents and ensure safety.
    Extend the tire’s life:when tire’s pressure is 10% pressure value under standard,the tire’s lifespan will reduce 15%.with in-time digital display of pressure and temperature value,TPMS can help driver to keep tire the standard pressure,so as to extend the tire’s life.
    Save Fuel consumption:when the tire’s pressure is 30% below standard,the fuel consumption increase 15%.TPMS can help drive to keep the tire’s standard pressure,cut fuel consumption.
    Protect automobile parts:if driving when the tire is not at the standard pressure(too high or too low),it will bring some abrasion to the engine chassis and suspended system.
    Guarantee the normally-operating Brake System:if the tire’s pressure is not in balance,it will make the vehicle run deviate in braking,so as to increase the accident risk.
    Monitor the tire in real time:TPMS can help driver control the tire condition easily at any moment in vehicle,so as to help drive to make right decision,and ensure safety.
    External TPMS
    Internal TPMS
    1.TPMS (Wireless-External sensors):
    a. Display
    b. cigar lighter charger
    c. external mounted sensor
    d. anti-thief nozzle
    2. Functions and Features
    Product Features
    (1) Real time monitoring tire pressure and temperature at the same time.
    (2) Display show pressure and temperature of 4 tires on screen.
    (3) Display show which tire is abnormal.
    (4) Powerful function include low pressure alarm, high pressure alarm, leakage alarm, high temperature alarm, low sensor battery alarm, low display battery alarm, signal missing alarm.
    (5) Alarm with beep sound and display screen red light flashing.
    (6) Sensor battery changeable.
    (7) Dual power supply of battery and charger.
    Alarm Function
    (1) Leakage alarm: The pressure decrease over 0.2Bar in 20 seconds
    (2) Low pressure alarm: The pressure is lower than standard about 25%
    (3) High Pressure Alarm: The pressure is higher than standard about 40%
    (4) High temperature alarm: The temperature of tire is over the threshold
    (5) Low power of sensor alarm: The power of any sensor is less than 2.4v
    (6) No signal alarm: Missing some sensors’ message over 25 minutes after it start to work
    Operating Functions
    (1) Pressure Unit setting: change Bar to PSI (pre-set unit is bar)
    (2) Temperature Unit setting : change °C to °F (pre-set unit is °C)
    (3) Standard pressure setting: increase or decrease (pre-set value is cold tire pressure 2.4 Bar)
    (4) High temperature alarm threshold setting: pre-set threshold is 80°C
    (5) Set up sensor: learn new sensor ID code when replace sensor
    (6) Exchange tires position: when mismatch sensor to tires, change position on display
    call me at 09053338777 , 09228335588, 3481728.. I am willing to give special price for the first few orders.
    There will be two models to choose from... Wireless External and Wireless Internal
    SRP: P11,000
    Advance Order: P9,000 for wireless or external TPMS
    mukhang maganda ito.hindi ba madaling manakaw.how much would it cost
    Quote Originally Posted by Ginnova View Post
    may anti theft nozzle naman yung tire cap, kaya di sya basta basta mahuhugot. as i've said, meron ding ibang models for internal... pero para sa mga gusto ng DIY ito ang maganda. May mga discussion dito sa tsikot about internal TPMS, sabi ng iba ingat din sa pagpalit ng gulong kasi baka madamage yung sensor.
    Apr 2010
    papa jedi... pa text or pm sakin price! thanks!!!
    Jul 2004
    nice!
    i agree
    a TPMS is important
    nice!
    i agree
    a TPMS is important
    Yup, di kasi lahat may built in tpms.. buti na lamg mayrong aftermarket.
    Quote Originally Posted by olidotcom View Post
    i texted You bro
    im accepting pre-orders for internal and external TPMS. please contact me at 09053338777, 09228335588 or 3481728
    SRP: P11,000
    may mga nagadvance order na po, as of today dalawa na... plus 1 for myself.
    Jan 2008
    Puede malaman saan gawa? Thanks.
Wireless  TPMS Tire Pressure Monitoring System
