Results 31 to 40 of 44
August 19th, 2015 11:27 AM #31
hi miko,
done. BUT, the squealing noise is still there (sounds like metal to metal). the noise diminishes when i hit the brakes. also to add, i just refaced the rotors and replaced with new bendix ct brake pads (front). could it be the rotors? but i didnt see any problem when braking hard, no vibration in the steering wheel whatsoever. the noise is coming from front wheel, driver's side. different mechanics tell me to:
1. reface the rotors.
2. replace brake pads
if i tell them just had it refaced, they said "pangit pagka reface, paulit natin". dont know what to do next.
August 19th, 2015 11:54 AM #32
One test I use when evaluating a student's brakes hardware refinish is to run a ball point pen across the new surface(radially). if the pen writes without skipping, is satisfactory, if it skips, the refinish is bad
- Jun 2007
- 187
August 20th, 2015 10:53 AM #34
are all the brake shims in place correctly?
did you put brake grease sa guide pins at sa pagitan nang shims?
vibration will cause metals to produce sound.
are you sure na nasa harap ang sound? madalas nagkakamali dahil minsan nasa likod pala sound. muka lang sa harap galing dahil sound travel faster than your vehicle can move forward.
- Aug 2005
- 183
August 23rd, 2015 01:59 AM #35Same thing with my toyota innova. Before I replaced the brake pads everything was ok. I bought orig brake pads sa cruiser sucat. Now there is a squealing sound even when I don't brake. It's intermittent. Minsan meron pag mag brake, na sand na yung pads ng mechanic para daw matanggal yung sumSayad. The thing is there is no problem with braking power. Ano kaya to?
August 23rd, 2015 02:48 AM #36
August 31st, 2015 12:25 AM #37
hi miko, thanks for the reply.
- im not sure. havent checked this.
- what is a brake grease? san makakabili nun? possible ba na hindi fully disengage yun brake pads kaya may sumasabit?
- ayan pa pala isa. actually when i had it checked, inangat namin yun harapan (naka jack) and let the wheel turn, wala naman yun tunog. baka nga sa likod.
problem ko lang, dalawang mekaniko na yun tumingin ang alam lang sabihin eh brake pad replacement, tumatama yun back plate saka rotor reface. hindi nila ako nasabihan about brake grease and shims.
August 31st, 2015 04:23 PM #38
dito mo lalagyan brake grease
tapos yung brake shims ganito itsura, dapat meh brake grease din at tama ang order at orientation
important na free moving ang slider at guide pins,
hindi dapat mag vibrate yung shims, kung meh brake grease yan mababawasan ang vibration all througout the calipers.
wag ka lang maglalagay grease sa rotor at brake pad material.
kung wala ka mahanap na brake grease, you can use moly or graphite fortified grease, MAG1 has them, you can buy them sa handyman/ace hardware/ etc...
normal grease will dry out quickly due to the extreme heat, 100-200 degrees.
OEM ba pinalit mo brake pads? if you have already refaced the rotor/ replaced the brake pad, tapos ok ang brake shims and you have applied breake grease already then check your rear brakes they might need repalcement and servicing.
- Aug 2014
- 23
September 29th, 2015 06:22 AM #40Mga bro help naman. I recently had my disk re faced . They charged me a total of 5180 php. 1200 each for the front disks, then brake fluid and repair kit 1580. Plus 1200 for labor. This is due to squeaking sound of my brake when i changed the pads to bendix. Ask ko lng pero i think alam ko na din sagot haha overpriced ba yung gawa nila sa akin? I'm having troubles kasi finding a good and honest talyer in BF paranaque area e. Kaya dun ko nlng pinagawa sa kung ano makita ko
Tesla Philippines
