Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
    Feb 2012
    #31
    i think you have installed an overly sensitive brake booster or feather trigger booster. what was wrong with the old booster anyway? if the booster does not have vacuum leak nor damaged in any way, try reinstalling it. just make sure you have 1 mm clearance between the cavity of the primary piston and the push rod at fully seated position. there is a brake booster push rod measuring tool for this. but in its absence, you can try to extend the push rod out forward lightly, then, use the master cylinder to reseat it. move the master cylinder out of the way and with your finger, push the booster push rod in, it should move in or retract about 1 mm.
    https://www.google.com/search?q=brak...ap%3B731%3B289
    sira na po kasi yung master sir lagi po tumatagas kahit palit repair kit na yung hydrovac naman po dati na po palang sira yun nung binili yung van ko hehe..
    #32
    Quote Originally Posted by tip_tipid View Post
    iang type ba o model ng hydrovac at brake master ang ipinalit? may pedal play pa ba bago kumagat ang brake, o sagad, no more free-play?
    Oo nga naman, baka wala na kasi free-play na kahit 3/4 inches.
    Tsaka baka nga naninibago lang si TS. hehe
    May 2009
    #33
    di bat mas ok yung walang foreplay kesa free play....hihihihi....
    IMO, ok na yan TS basta hindi naglolock ang preno lalu na kung emergency stop. di ka pa mapapagod sa kakaeffort sa pagpreno.
    nung nagdrive ako ng hyundai accent todo reklamo mga pasahero ko dahil napakasensitibo yung preno. pero nung tumagal na sa byahe paprobinsya swabe na. unlike sa pickup ko at sa innova ng ate ko, swabe parati ang pag preno ko. walang reklamo mga pasahero.
    Feb 2012
    #34
    Tnx po sa lahat ng sumagot he he OK na mga sir
    tama po kayo Mga Sir ang sarap na gamitin he he medyo nasasanay na ako :D
    Oct 2014
    #35
    Naalala ko tuloy nung nag drive ako kasama uncle at mother ko pag pumepreno ako ang lakas ng preno kasi bago pa kaya mejo nag reklamo. Nasabihan pa tuloy ako na mas maayos pa mag drive si GF kasi pag sa car nya swabe yung preno. :sharp_teeth:
    #36
    Quote Originally Posted by miked View Post
    haha, iba yun, patawarin!
    #37
    Quote Originally Posted by sotel View Post
    kung galit ka sa biyenan mo o sa tita o tito mo paupuin mo sa harap tapos biglang apak ng preno sabay ooopppsss! PI na mekaniko hindi man lang inayos maigi ang preno!
sobrang lakas na brake
