Page 5 of 42 FirstFirst 12345678915 ... LastLast
Results 41 to 50 of 420
    Apr 2005
    #41
    konti na lang, ita-try ko na ito. gusto ko kasing ipa-check tires ko. parang every week kailangang magrefill. sabay change to nitro na.
  2. #42
    maverick: Baka may tagas tires mo pa check mo na rin.
    #43
    Quote Originally Posted by pepengtom
    caloy, 75 per tire ba doon sa tireboy?
    pina deflate ba muna ung gulong mo bago sinalpakan ng nitrogen?
    yes sir, 75 petot per tire. SOP nila to deflate the tire before charging it with nitrogen..
    unlimited refill nila sa tire boy..been there 3 times already..the first was a week after charging, nilambotan ko..tapos pa fill ulit..experiment ba..second was 3 months after, then another 3 months
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    #44
    just wanted to share...
    just had my 18inchers filled with it and so far the ride became softer...
    #45
    #46
    Sep 2004
    #47
    same psi din ung gagamitin di ba?
    Aug 2003
    #48
    you can use a higher psi if you wish. you can dial in a higher psi and not risk the danger of blowing up your tires when they heat up in the course of travelling -- unlike tires inflated with plain air. that why it's being touted as a fuel saver, less rolling resistance for higher inflation rates.
    Sep 2005
    #49
    Hmm.. Pede kaya magparefill ng CO2 tank, ung pang airgun ng N2 sa mga shops? para kapag lumambot ung gulong mo e matagal mo na kailangan pumunta sa kanila for refill?
    May 2004
    #50
    ano na update sa nitro filled tyres?
Nitrogen for Tires [Merged]
