Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
    Jan 2004
    Same happen to me, pero ni-re-refill ko na lang, dahl bihira namin gamitin yung kotse kesa ipagawa, ang estimate kasi more than 10k kung ipa-rerepair.
    Yung one bottle ng STP Power Steering Fluid is around 75.00 lang, it will last for three months.
    Jan 2008
    kaso po sa akin, every 2 or 3 days ako nakakarga...ang sabi sa akin nung mekaniko...palitan ko daw ng surplus yung shaft kasi may gasgas
    ok po ba yun...san ba pwede bumili nun...
    Jan 2003
    Quote Originally Posted by threed View Post
    hmm... shaft ng ano? na-check mo ba kung saan yun leak sa power steering? pwede kasi sa gearbox, pwede din sa tubo, or dun sa pump. medyo mabigat ang magpa-ayos nyan since kelangan iwan yun sasakyan. pinpoint mo muna kung saan ang location ng tagas at kung nagbago yun manibela. bumigat ba? may tunog pag kinabig? san tumutunog etc. kung basta dadalhin mo lang sa mekaniko eh baka mapamahal lalo na kung taga yun mekaniko
    Nov 2003
    check where the leak is comming from and have it fixed.
    Nov 2007
    Gaano ba katagal bago maubos ang fluid sa reservoir? at ilang weeks or months ang normal na pag refill nun?
    Nov 2003
    ideally di sya dapat nagbabawas unless there is a leak.
    Nov 2007
    *speedyfix - nagpapalit na ako ng oil seals sa power steering kaso mukhang naging worst, 1 day pa lang ko ubos lahat ulit ng fluid at basang basa ung sa ilalim ng sasakyan.... ano na kaya problem nun?
    Nov 2003
    sino nagpalit? siguro dapat ibalik mo at ireklamo mo.
    Oct 2003
    *Onynz
    Same thing happened to me sir. Pero, i was fortunate enough na nangyari yung pagleak after 1 hour of testing sa talyer.
    Kaya, binaba ulit ang power steering. If i am not mistaken, they remedied the problem by putting 2 oil seal on each side. Bale naging 4 na ang power steering oil seal ko. OEM yung mga PS kit na binili nila.
    All in all, almost 6k yung gastos ko sa paggawa.
    So far, so good.
    Jan 2008
    just had my ps hoses replaced. paraehong tumagas. it was easy to spot kasi there was a puddle of ps fluid under the car.
    i suggest you have it checked out. preventive meaintenance is less expensive than corrective maintenance.
low on power steering fluid
