Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
    May 2011
    #21
    On possible debris on the magnetic tip, is this something that can be cleaned?
    Yes, with an OEM toothbrush on the reluctor wheel teeth and special paper towel dampened in mineral oil to wipe the sensor tip.
    Just kidding on the OEM and special.
    Jun 2009
    #22
    Quote Originally Posted by mina_nuka View Post
    Haha. Thanks sir! Will try ko DIY clean.
    Jan 2009
    #23
    It could also mean that the sensor is not picking up all the teeth on the hub. So instead of a continuous steam of one and zeroes, it's skipping some of the teeth and the ABS computer interprets it as a slow-moving wheel or it having a different-sized (larger) wheel.
    Check if the sensor distance has changed.
    May 2011
    #24
    The wheel speed sensors do not send 1s and 0s. The signals are analog AC not digital signals. If you watch the waveform on an oscilloscope, the pattern is not square waveform
    Jan 2009
    #25
    That's nit-picking. They may be analog at the sensor input but they are converted to and processed as digital signals (PWM), in-computer. The ABS computer only cares about counting the number of peaks per unit of time to determine the wheel speed. If one wheel is perceived to be slower than the others (ie. The sensor is not detecting all of the teeth), the computer might mistaken it having a larger-diameter wheel (ie. turning slower than the others).
    May 2011
    #26
    Clarifying not nit-picking.
    Not to make things more confusing to those who doesn't know.
    Jan 2009
    #27
    I understand. But in all intents and purposes, the input may be electrically analog, but the information being collected is digital.... that's what I meant.
    May 2011
    #28
    That's clarification.
    Not to make you take your hypertension pills.
    Jan 2009
    #29
    No, I'm calm as calm can be. Posted texts doesn't do justice to the actual expressed human emotion.
    It just so happen that when talking about the intricate workings of motor vehicles, you're in my wheelhouse.
    #30
    wow!
    a lot of technicalities.
    i wonder, does TS know how to go about all this?
Honda City ABS error - wicked problem
