Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
    Jan 2009
    #31
    wow!
    a lot of technicalities.
    i wonder, does TS know how to go about all this?
    Well, cars are a fair bit technical to maintain, that's why it's a multi-billion peso industry. And since the TS isn't considering having it repaired by the dealer, and none have actually had that same issue happen to them, there's no other way but to speculate, albeit, do educated guesses, on what the problem might be. In other words, we're all just throwing good ideas. It's really up the TS to read up some more about the topic and evaluate the ideas, then try to fix it himself or through a 3rd-party mechanic.
    He can always go the non-technical way and bring it to the dealer. Though, he would have to pay a handsome fee.
    #32
    my guess is, dadalhin niya sa mekaniko.
    i think TS is a non-tinkerer.
    good luck, TS.
    Apr 2009
    #33
    In case the ABS sensors are accidentally (or intentionally) sprayed with an undercoat, is it possible for them to be cleaned thoroughly to function flawlessly like it should? if not, you have no choice but to replace them.....
    Jun 2009
    #34
    Update lang: i had the sensors cleaned but the error still persist. I would have it scanned again then change sensors.
    Any suggested suppliers? Yung mura. ;)
    Jun 2009
    #35
    Update: replaced abs sensor right front and rear left. But issue still persist. Dunno what is next?!
    #36
    What may error pa din? Have you tried to reset after replacing the sensors?
    Sinusumpa mo na siguro undercoat ngayon. Hehehe
    Nov 2019
    #37
    Quote Originally Posted by frost2 View Post
    Hello did you fix/ clear your abs codes/ fault? Because im hving the same problem exactly as yours. Mine is 2009 model. Did also exactly same as yours. Replaced abs module, sensor and clean wheel bearing but still code 71 - 33.
    Really same as you did."parehong pareho". What you explained is the same occurs and did in my 2009 city.
    My question is did you already fix it and clear the codes?
    Need your inputs what you did to clear the codes.
    Or we have the same problem until now?
    This happens since october 2019 until now.
    Tnx
Honda City ABS error - wicked problem
