Results 11 to 20 of 24
    Quote Originally Posted by bokswager View Post
    sir, pwede bang sabhin sa mekaniko na magpapa brake flush ako ?alam na ba nila ang procedure na gagawin sa ganon?
    Pag sa kanto-kanto na talyer. Babawasan lang niya yun sa reservoir then palitan pero sa ibang shop meron silang machine nag higop para mawala sa whole line yun lumang fluid.
    Oct 2005
    Nagtanong dati ako sa shell brake flush nila nasa 1.2k kasama na daw brake fluid. Gamit nila brake fluid is mag1 dot 3.
    Quote Originally Posted by toast View Post
    Mano-mano?
    Oct 2005
    Mano-mano?
    Sabi lang sa akin meron daw silang vaccum pump to remove the old fluid. I confirm ko nga ulit pag nakapasyal ulit dun.
    mano-mano is fine. any mechanic worth his salt could do this job correctly. bleed the system enough and you could potentially replace all the brake fluid in the system. ang nakikita ko lang sa vacuum na advantage ay pwede kang mag bleed ng brake system mag isa as opposed to a two-person job of "bomba" - "pirme".
    Apr 2014
    Pwede diy 1 person.
    How to do a Complete Brake Flush and Bleed - YouTube
    Kung meron naman vaccum eh di doon ka na.
    Jul 2014
    when is the time po sa car natin para masabi natin na need na natin ng brake flush? ung mileage kasi sakin mag 70k na, matagal na ko hindi nagcacasa, sa talyer lang ako madalas kapag change oil. help nman po. thanks
    regardless of distance, every 36months
    Ideally, every 2years. Humidity here is constantly high. Brake fluid is hygroscopic.
HELP:Brake fluid leak
