Results 431 to 436 of 436
- Dec 2013
- 527
November 13th, 2024 04:36 PM #431
- Nov 2019
- 1,239
November 15th, 2024 01:44 PM #432Question lang just in case may maisuggest paano i resolve yung ingay every morning sa brakepad.
Newly replaced pads yung front ng car last June.
Pero every morning, may ingay yung brakes.
Pinalinis ko na from suking shell station last month.
Pero bumalik pa rin.
I haven't check the brake fluid though, pero parang may laman naman.
Ano po kaya cause ng ingay nito?
MUX 2015 AT yung car.
November 15th, 2024 02:22 PM #433
- Nov 2019
- 1,239
November 15th, 2024 04:47 PM #434
- Dec 2013
- 527
November 26th, 2024 04:35 PM #435One possible issue is that the steel rotor discs during the night and early morning acquires moisture during that time and that creates rusts which will cause the screeching issue because thin layer of rusts that your rotor discs had acquired overnight is in the middle of both your brake pads and rotor discs and during contact both the rotor discs and brake pads are scraping off the accumulated rust due to the humidity in our region which causes the sound you are hearing every morning, another possibility is that your brake pads is taking time to adapt to the uneven surface of the rotor discs due to wear and tear of the previous contacts between the stock brake pads and rotor discs so parang lumalapat palang siya doon sa mga edges and uneven surfaces that was the caused of wear and tear normally sa brake pads and rotor discs until the brake pad surface evens out to the surface of the rotor discs it would have gaps which the air can pass through during braking and lastly another possible reason is that your rear brake shoes have been worn out and the uneven friction material banda sa upper or lower end ng friction material has a gap for it to make whistling noise just like what happened to my friend who has a Navara pickup akala niya yung brand new brake pads nagiingay pero yun pala yung brake shoes sa rear uneven na which leaves space to create noise while braking.
- Dec 2013
- 527
December 13th, 2024 12:34 PM #436By the way guys may isang company and brand that is trying to deceive people into thinking that they are a Japanese company or from a Japanese origin, the company and brand name is Masuma with an orange and black packaging, what they are really is a mainland China aftermarket parts company that rented an office in Japan so that they could tell people that they are a Japanese company that sells automative products that come from mainland China, just the same as what Miniso and Mumuso have done where they copied the Japanese and Korean companies designs then rented an office in a building somewhere in Japan for Miniso and South Korea for Mumuso then try to introduce themselves as a company from Japan or South Korea but the truth is they don’t have presence in their claimed “headquarters”. If this is their integrity in introducing their companies then what more about other things.
Tesla Philippines
