Results 121 to 130 of 133
September 30th, 2016 05:45 PM #121
Most common practices:
Replace brake pads when the friction material is thinner than the backing plate of the pads
Replace the pads if they are contaminated by petroleum products
Replace the pads if they had been overheated
Resurface the brake rotors if they are warped, tapered, cracked or have less than 0.020 inch above the minimum thickness
Replace the brake shoes if they have less than mm above the river heads of friction material
Replace the shoes if the had been contaminated by petroleum products
Replace the shoes (bonded type) if the shoe lining is equal to or thinner than the shoe arc
Replace the brake drums if they are cracked or less than 0.020 inch smaller than the maximum diameter. The brake drums must be within 0.020 inch diameter of each other on the same axle
Replace the brake fluid at least every two years.
September 30th, 2016 05:49 PM #122
- Aug 2012
- 2,767
September 30th, 2016 05:53 PM #123
- Oct 2015
- 1,054
September 30th, 2016 06:01 PM #124Tires could also be a factor. Also, friction material hardening over time. Do your rotors have grooves on them?
- Oct 2014
- 162
October 4th, 2016 11:11 AM #125My brake does not still shows sign of concern. But it is till necessary to reface the rotors even if not changing the pads? Or just plain cleaning of my brake system all 4 wheels and replacement of brake fluid is enough? or do i have to change na lang the pads in service for more than 5 years? Thanks mga Bro.
October 4th, 2016 11:22 AM #126
your new brake pads are generally flat when manufactured, when you install them on used brake rotors that are not flat, the contact between the rotor and the pads are not at 100 %. it requires a long break in period or bedding in period for the pads to be 100% contact with the rotors. if the friction surfaces of the rotors at least appear to be flat, you might be able to get away with it by just deglazing the rotors (using a coarse sandpaper 180-240 grit) to remove the glaze and shorten the bedding in time. when in doubt, have them resurfaced.
- Jun 2016
- 43
October 19th, 2016 11:50 AM #127
December 23rd, 2016 09:15 AM #129
my brake system is funny.....
just serviced my front brakes kagabi at eto mga ginawa ko:
1. brake pad replacement (bosch)
2. replacement of rubber boots ng slide pin at lock bolt....as well as greasing it with silicone grease.... (hindi ko pinalitan ang square seals at rubber boots ng piston)
3. disc refacing. 21 mm thickness after. (replacement limit is 20.6 mm)
4. replacement of the brake fluid pati na rin sa clutch.
ngayon, mas malambot yung first pump kesa sa second pump during brake application....after 1 liter of brake fluid e ganun pa rin.
i suppose malambot nga siguro ang bosch...humihinto naman.
still under going bedding-in procedures as per the instruction manual ng bosch.
- Jan 2010
- 283
December 23rd, 2016 01:31 PM #130
