Results 41 to 50 of 99
- 53,883
December 22nd, 2018 11:41 AM #42
It mimics how the wheels & tires are rotating under load. Note that it's spinning with a force-applying cylinder while it's computing for runout....unlike regular balancers where the wheel just spins freely.
Roadforce has proven to remove the vibrations regular ones can't.
Think dyno vs butt dyno.[emoji4]
December 27th, 2018 08:32 AM #44
December 27th, 2018 09:28 AM #45
December 30th, 2018 12:04 AM #47
Dito ako muntik na mahulog. I was new to cars then having just learned to drive. They let me mount the car in position and I keep over correcting myself kada signal nung nagga-guide. Nung sinilip ko due to the worried face nung boy almost 1 inch or less na lang pala yung sa front passenger tire and only the rail guide sa kabilang side sort of saved me.
For being a proper tire center, sa kanila rin yung old school vulcanizing - yung pasak style. Experience ko pag ganun nagkaka-bukol din later on. So haven't been back at this SC for some time kahit ang lapit ko lang sa kanila.
Dito rin ako nagtataka sa mga tire boys ng mga shops. Tires have this orange and yellow dots/marks to align to the heaviest part of the wheel which is usually sa may valve stem yata for minimum weight strips. Kung tama ang pagka-mount just by that rule of thumb, minsan di na talaga kailangan ang lead strips or just bare minimum lang. As I see it, they usually just mount the tire and then compensate with weights later. Sa dami ng lead strips na dinagdag, I wonder if ganun ba ka-off ang manufacturing tolerance ng either the tire or wheel or both to require that much amount of lead weights? Surely may impact din ito sa FC.
Eto daw yung principle ng road force balancing:
December 30th, 2018 12:13 AM #48
when did you have the vulcanize done? 10yrs ago? baka theyre using proper patch kits na..
December 30th, 2018 12:20 AM #49
Maybe just a year or so ago. But I didn't go through with the vulcanizing job coz that's the repair type that they're offering nga. Not sure if it's the same today.
Tesla Philippines
