Page 17 of 341 FirstFirst ... 71314151617181920212767117 ... LastLast
Results 161 to 170 of 3407
    #161
    That's how most of the pipz at the usa forester forums see it.
    Here though, the Overdrive button works by adding the last gear, making it able to go faster but if and only if you're already beyond the 2nd to the last gearing ratio. I actually drove an AT before with this feature and this is exactly what it used to do.
    I'm just not sure that 'power' = 'overdrive', and it doesn't say so in the manual (or anywhere else, apparently).
    May 2004
    #162
    Try this. Accelerate from a full stop. Keep your foot at constant throttle, say not lower than 1/4. Count the number of gears it shifts to and (this is more important) take note of the rpm it shifts until you hit a speed of 120 kph. Now repeat this process but with the power button on. That should finally put your question to rest.
    May 2004
    #163
    I've learned not to believe everything the casa tells me lalo na in the case of an AWD, turbo charged, 4EAT proshift transmission et al.
    How about a breakfast EB?
    Aug 2005
    #164
    "power" button = overdrive with lockup torque converter..
    #165
    Quote Originally Posted by jjmichaels View Post
    Hindi ko nga halos ma-feel yung shifting eh. Feeling ko 2 gear lang meron. hahaha. Maybe you can try on your unit. You from manila? Layo ng house ko eh.
    #166
    Quote Originally Posted by HyBrideVo View Post
    What's a lockup torque converter?
    #167
    Yung sa overdrive, proven ko na yan. I was wondering why my old Galant AT before was more thrifty on fuel when the OD button was on, then when I counted the gearing, pag naka-off pala siya, 3 gears lang!
    May 2004
    #168
    Quote Originally Posted by pup2 View Post
    Aug 2005
    #169
    Heto po Torque Converter
    Heto pa added info sa A/T
    #170
    Thanks. I think it indeed likely that it's OD. Just waiting for Subaru's e-mail response.
Subaru Forester
