Page 235 of 349 FirstFirst ... 135185225231232233234235236237238239245285335 ... LastLast
Results 2,341 to 2,350 of 3483
    Nov 2014
    #2341
    Mga sir nandito po ako ngayon sa japan tanong ko lang po kc po gusto ko pong palitan ng busina c fort ko. Ano po ba magandang ipalit na busina? Salamat po sa sagot.
    Sep 2006
    #2342
    Quote Originally Posted by paos View Post
    anong tunog po ba ang preferred nyo? yung parang metallic sound? or yung horn type ang sound?
    ako bosch europa ang gamit ko.
    #2343
    Quote Originally Posted by Servus View Post
    as per manual: CD/DVD video, MP3, WMA, JPEG, WMV, DivX, AVI and MPG
    thank you for the reply sir. this helps a lot.
    Nov 2013
    #2344
    mga guru please help po.. kanina po di na umandar ung fortuner namin. ayw na nya magstart parang d umaakyat ung kuryente so ang ginawa namin nagpalit kami battery kaso ganun pa din. sabi nung officemate ko baka daw sa starter. jan 2013 po namin nabili un sasakyan. 4x2 authomatic po. may trusted mechanic po ba kayo na kakilala na puede magservice? nasa office po kasi ung sasakyan sa makati. sana po matulungan nyo ko
    Nov 2013
    #2345
    follow up question po. under warranty pa po kaya ng casa un? bale jan 2013 acquired po and 55k po ang naitakbo. sana po matulungan nyo ko
    #2346
    ^did you check the transmission lever kung nasa Park ba?
    Nov 2013
    #2347
    yes sir nasa park po sya
    Sep 2006
    #2348
    when you turn the key to the ON position, does the instrument cluster lights come up? when you twist the key to the START position, does the starter engage in any way even for a quick moment? Or nothing at all? Do you hear any mechanical click sound at least?
    warranty is 3 years so you should be covered till end of the year i think.
    May 2015
    #2349
    Quote Originally Posted by yaelting View Post
    it should be still under warranty. 3 years or 100k ang warranty
    Apr 2008
    #2350
    planning to install backup camera sa fort 2015, naka set na ba wiring nito papunta dun sa HU?
Welcome to all owners of Toyota Fortuner  [continued]
