Results 21 to 30 of 54
- Dec 2013
- 6
December 3rd, 2013 05:42 PM #21Problem ko kasi by the time na nagmimintiss na yung aircon before bumigay ay nakikita kong nag 8 or wiggle na yung pulley. Pinapatingnan ko agad sa mekaniko at lagi na lang nakikitang may gasgas n ayung shaft. Akala mo kinain ng pulley yung shaft.
Ang gusto kong malaman ay possible root cause nung pagkasira ng shaft. Di ko kasi malaman kung nag otso muna yung pulley kaya nagasgas yung shaft or due to wear and tear kung saan unang bumibigay sa rubbing yung shaft.
Habol ko kasi is ma prolong yung buhay ng compressor ng atleast 5 years rather than 3.
December 3rd, 2013 05:56 PM #22
Pwede na on aircon after you start the engine. Don't make it complicated.
December 3rd, 2013 07:02 PM #23
I just turn on the aircon as soon as the engine has started. Nothing more complicated than that.
Sent from my Nokia 5110 using Tsikot app.
December 3rd, 2013 07:43 PM #24
December 27th, 2013 06:15 PM #25
mga master,
ung tick na tunog anong nangyayari pag naririnig un? sa compressor ba un?
December 28th, 2013 11:08 AM #26
- Mar 2008
- 36
- Mar 2008
- 36
January 16th, 2014 05:21 PM #28By the way ang practice ko e: 1. turn on engine 2.turn on fan only 5. after 3-5 mins turn on A/C. My ride is Honda EK 99 5 years sa akin wala akong pinagawang sira ng A/C ko maliban s maintenance, wear & tear parts.
January 22nd, 2014 12:45 PM #29
- Nov 2013
- 2,077
May 2nd, 2014 03:24 PM #30Sharing an old article: Honda's Tips on Proper Use of Car Aircon
Summer is officially here! Honda Cars Philippines, Inc. imparts practical tips on proper use and maintenance of car air-conditioning unit to beat the summer heat. The air-conditioning unit is an indispensable item in today's car especially in a tropical country such as ours.
In new cars, problems hardly ever occur but after a length of time, depending on the working conditions, its efficiency naturally diminishes. So, it is advisable that car owners know how to properly use and maintain the car's air-con system in order to obtain the longest possible service.
Here are the following suggestions:
1. Check the position of the compressor control switch (A/C knob) if it is in the 'open' or 'shut off' position. One should shut if off before starting the engine. This will avoid unnecessary drag caused by the compressor while cranking the engine.
2. Once the engine runs on, switch the fan on first. Blow the air-con's fan at the highest speed for about a minute in order to clear away the hot air trapped in the air-con's ducts. Then, depress the A/C knob to turn the compressor on at coolest temperature. The next step is to adjust the fan speed and temperature control switch to the level most comfortable to you.
3. Switch off the compressor before cutting off the engine. Keep the fan on at highest speed so that it blows away all humidity trapped inside the evaporator or 'air-box.' This will help eliminate the smell of stale air when you subsequently turn on air-con again, and at the same time, to lengthen the service of the evaporator. The process only takes about 2-3 minutes.
The smell of stale air inside air-con ducts can be eliminated by simply parking your car in a sunny, open space. Open all doors and leave the car for about 2-3 hours or until the smell finally disappears. Make sure that the sun's ray reaches the greater part of the cabin. If the stale smell still persists, however, consult a reliable service center nearby.
Honda's Tips on Proper Use of Car Aircon - Auto News by AutoIndustriya.com
Tesla Philippines
