Results 201 to 210 of 258
March 27th, 2022 07:47 AM #201
Same experience with Camel e-fan. We HAD four stand fans bought 3 plus 1 free. Lahat sira na. Amoy sunog ang motor at hindi na umiikot. Kaya balik Asahi kami.
Sent from my CPH1911 using Tsikot Forums mobile app
March 27th, 2022 09:57 AM #202
If you've lived long enough and remembered the electric fans of the 70's and 80's, they also suffered from sleeve bearing lock-ups if you don't maintain them. I remember dad used to dismantle the fans every so often or it either gets noisy or starts to smell burnt.
In fact, that's likely what prompted 3D to come out with their "never-oil" ad campaigns in the 80's, to highlight their motor's reliability.
My memory of electric fans then is that they were more "sirain" compared to modern ones. Rusty fan guards, finicky oscillation mechanism, etc. Most of these issues are practically non-existent now.Last edited by oj88; March 27th, 2022 at 10:00 AM.
March 27th, 2022 10:15 AM #203
- 53,883
March 27th, 2022 10:19 AM #204when our fans back then got stuck up, i tried to re-lubricate them using singer sewing machine oil. but the fix turned out to be only temporary.
for a longer fix, i brought them to this fix-it shop near the house. the guy would replace the bushings.
our kdk fans are now stuck up. these are the older models with 1/2 speed setting. "we want a breeze and not a pang-guryon wind." alas, wala nang gumagawa nang ganito ngayon.
but the guy had since moved...
highs.
March 27th, 2022 10:24 AM #205
March 27th, 2022 10:27 AM #206
Singer oil... I still use it today to lube practically any machine in the shop, including fragile stuff like PC fans.
Dad use Singer oil too and yes, sleeve bearings weren't as good back then.
Our KDK box fans from the 90's would've been still alive if they weren't banged-up so bad with people tripping over them and falling down. I think most of our old fans died that way and not because the motor quit.
- 53,883
March 27th, 2022 10:34 AM #207the ancestral home still has an ancient 60s westinghouse all-metal table fan, with rotary switch. it still works.
no one wants to claim it out of the house, at baka raw multuhin.
- Dec 2013
- 680
March 27th, 2022 03:01 PM #208The singer oil is too thin doc. I use excess engine oil i have lying around. Lasts a whole lot longer. 2 drops sa harap at likod. Works wonders.
Sent from my CPH1937 using Tsikot Forums mobile app
March 27th, 2022 03:43 PM #209
It is advised that sleeve bearings in fan motors must be lubricated using non-detergent oils. Automotive oil has detergents in them.
- Sep 2021
- 872
March 27th, 2022 04:20 PM #210The only fans I consider buying nowadays must have a 5 year warranty on the motor.
So far yung mga ganun is Asahi & some Hanabishi models.
