Results 191 to 200 of 258
- May 2007
- 275
August 25th, 2021 12:18 PM #191Puro asahi din kami, para maiba we bought a Hanabishi Windmill desk fan - ingay pala nito kahit lowest setting di pwede sa kwarto tsk tsk
August 25th, 2021 12:23 PM #192
Anyone who has used inverter fans for more than 2 years? Wondering if they really last longer.
March 26th, 2022 08:09 AM #193
A frustration of mine are the quality of affordable electric fans (bintilador) in the market. I’m talking about the affordable ones like Dowell or Camel. I have no issues with the body. It’s the motor that gives up after approximately 1 year of use. Same thing with industrial fans being sold. They are not made the way they’re used to.
- Mar 2008
- 53,883
March 26th, 2022 09:52 AM #196by coincidence, i just purchased a stand fan last night.
i had a hard time, as i wanted one when rollers or wheels, and most of those on display didn't have 'em anymore.
anyway, i got one. it was, coincidently, also cheaper than the others.
when i got home and proceeded to assemble it, that was when i found out why it was cheap.
the plastics were more manipis than i initially imagined possible, and the build quality was ... cheap.
assembling the stand was a huge chore, and a huge surprise!
wala nang cast iron frame and pabigat sa base!
instead, the frame was plastic, and it was heavied down by four plastic packs of a strange material that i will refer to as "dark brown bukbok".
i had to re-seal the packets, as one had already started leaking.
installing the stand was also a chore, as they scrimped on the manufacture. the nuts came loose, and i had to do some mechanical gymnastics to put them back in.
and the fan blade guards were "not built to swiss horological standards".
rant.
apologies.
at least, the three speeds and the swivel, work.
March 26th, 2022 10:38 AM #197
The 4 I purchased in S & R yesterday is buy 1+1 at P1,999 so, it turns out to be 1k each. The base is flat & heavy. I just hope it lasts a lot longer than the others
March 26th, 2022 10:41 AM #198
Have had good performance and reliability from the following brands:
Hanabishi
3D
KDK
Asahi
I also have a Vornado 660 circulator... gets a breeze and the A/C airflow going around my irregularly-shaped living room.
Just know and understand what you need.... a traditional fan vs circulator. They have very different use cases, granted with some operational overlap.
One safety feature to look for is thermal protection. Motors can spontaneously fail (locked rotor, shorted windings, etc.), overheat, and start a house fire. Those equipped with a thermal fuse will trip before the motor gets too hot.
March 26th, 2022 02:44 PM #199
We use standard electric fan and those with steel blade last longer compared to plastic.
- Dec 2013
- 680
March 26th, 2022 03:39 PM #200+1 we bought ours 2003-04. 2 units. 1 died last year. Bearing problem probably. I replaced the capacitor on the other one last month and it is still running fine.
Sent from my CPH1937 using Tsikot Forums mobile app
Tesla Philippines
