Page 12 of 22 FirstFirst ... 28910111213141516 ... LastLast
Results 111 to 120 of 211
    Jan 2016
    #111
    Here's the unit I bought...Click image for larger version.
    No free kabit doon sa service center?
    #113
    Sir 12vdc, would you know how I can fix this? This outlet is for water heater. But there is no ground wire. I bought the stiebel eltron that I saw posted here. Thanks.Attachment 35861
    Where are you installing your heater? Anywhere near an exposed rebar that may run all the way below ground? All outlets should have a standard 3rd earth line by code, sir. Can't you have your electrician add? Use the universal 3-prong.
    Mar 2004
    #114
    Steibel Eltron heaters have free installation. Maybe you can tap the ground onto the pipes? Some installers don't even tap the ground wire.
    #115
    Pipes now are either PPR or PVC.
    Aug 2004
    #116
    What's the diff pala between the common PVC and more expensive PPR? Longevity?
    Sent from my SM-A605G using Tapatalk
    #117
    Fusion welds on way thicker PPR vs PVC glue. Longevity & pressure/tension thresholds. When done right, PPR joints have greater chances to be leak-free from the get go & would remain so. PVC more hit/miss + w/ constant water hammering, they can leak after a while.
    #118
    PPR are rated for much higher pressure vs PVC. I use them for high pressure air lines.
    Jul 2013
    #119
    Boss, sorry for asking you this. Our rented house (an old one like more than 50 years old hahaha) is modeled after an American house (much like the rest in the neighborhood).
    Kaya naman ang mga socket namin ay 240V at 120V sa isang outlet (in pairs yan). Problema is yung normal plug natin yung 120V haha. But DIY guy naman ako so kinonvert ko sila sa 240V and during the process napansin ko nga yung 3 wires. Yung 2 wires ay 120V each at isang ground wire.
    How do they do make wire? Additional cost ba ito kung magpapagawa ka ng bahay tapos may ground wiring all over the house.
    #120
    Quote Originally Posted by Lew_Alcindor View Post
    In this case, just identify the specific outlets where you'll plug your appliances that ideally need grounding.... like heaters, ACs, fridges, kitchen equipment, etc. Have your electrician route an earth line for those to save on cost.
Water heater for Showers
