Results 171 to 180 of 211
- 53,883
November 12th, 2020 06:32 PM #172we use "jett" tankless electric heater.
recommended by a kakilala in the building industry. we were given the contact number, many (6? 10?) years ago.
i couldn't find it in the mall.
it's still ok.
November 12th, 2020 06:33 PM #173
November 12th, 2020 06:38 PM #174
Panasonics & these above did not fare well nor last long in hard water conditions here. Coupled w/ good softener systems, they should serve as they have you guys in the capital. Your water there is soft from my recollection.
- 53,883
November 12th, 2020 06:40 PM #175
November 12th, 2020 06:52 PM #176
Instant multi-point heaters have much smaller tubes, between the inlet & outlet valves, to slow the flow down as they heat the water passing thru. Hard water calcificifies when heated. Once the scales clog those small diameter tubes, you're looking at either servicing or replacing. You guys are blessed to not have homes sitting on limestone bedrock like ours here are.
The individual storage only has the heating element, relief valve & thermostat. It heats what's stored. Water doesn't pass thru small tubes. It's not hardwater-proof but trouble-free service life is relatively longer.
November 14th, 2020 09:33 AM #178
November 14th, 2020 09:36 AM #179
- 53,883
November 14th, 2020 10:17 AM #180
Tesla Philippines
