Page 17 of 22 FirstFirst ... 7131415161718192021 ... LastLast
Results 161 to 170 of 211
    #161
    A lot more efficient than I thought then. These things are substantially more expensive though. And there are on demand heaters with about the same power consumption already.
    If you don't mind bro, do you do a lot of high end projects like hotels? I noticed most of the stuff you recommend are on the higher end of available options.
    The storage? They're priced about the same w/ the Pana instant multi-point. Yes, there are a lot of less popular brands of lower initial cost. With heaters, softeners, & appliances, I'd usually point where there's good parts support.
    On projects? Don't really have that luxury to choose blessings, good brother.[emoji120] We simply go where there's work & do whatever's asked...like they were our own. Year in & out, can't help but notice the worth of many a product often shunned due to perceived high initial outlay. Just grateful for em chances & trust to have a bit of 1st hand play on stuff here & there....some I can't imagine owning.[emoji120]
    #162
    Quote Originally Posted by iandvo View Post
    yup. kaya i think it would be better if per shower has its own water heater. adjustments would be per user depende na sa desired temperature and within easy reach. pero what if the two bathrooms paminsan mahina ang water pressure? i read somewhere na its better to have a mechanical type one sa heater kasi hindi pressure dependent. and if this is the case, kelangan ba ng water tank kahit maliit lang to augment the needed water pressure for the heater to function properly?
    the temp control knob is just above our heads on the wall, where the heater is.
    we just reach up and adjust to our desired temp. it's not a chore at all.
    and it beats getting more exotic equipment.
    #164
    That general data is vs conventional centralized storage unit use where it's left on all the time....relying on the thermostat. The system I shared above was more an empirical hybrid. Individual, low capacity, low power, switched on upon demand, off when done.
    Real everyday life doesn't always follow everything we read.[emoji4]
    Mar 2004
    #165
    Have been using Stiebel Eltron multi-point instant water heater ... with our use, they last about 10-15 years ...
    Oct 2007
    #166
    ok na rin pala. how much did this cost you before?
    #167
    Must remember to consult you if I get to do another project. You know all the nicer stuff hehe.
    Stiebel also has another brand available locally, AEG. I suppose this is their budget brand?
    AEG Water Heater
    My in laws have been using one for around 3 years now so too early to tell how durable it is. They also have a low pressure 3.5 KW model.
    #168
    AEG Water Heater
    Same lang Stiebel Eltron and AEG, they rebranded lang to Stiebel to appear more high end hehe.
    Stiebel Eltron yung heater ko now. Works well naman, fits the 20A max capacity that my stock breaker came with. No issues for the past 1.5 years I've had it.
    #169
    Uy pareho lang nga! Di man lang binago yung kaha haha.
    Mas high end nga naman pakinggan yung Stiebel.
    #170
    Ito din mismo gamit ko
Water heater for Showers
