Results 111 to 120 of 211
BANNED BANNED BANNED
- Sep 2015
- 13,917
February 17th, 2020 08:06 AM #113
Where are you installing your heater? Anywhere near an exposed rebar that may run all the way below ground? All outlets should have a standard 3rd earth line by code, sir. Can't you have your electrician add? Use the universal 3-prong.
February 17th, 2020 08:19 AM #114
Steibel Eltron heaters have free installation. Maybe you can tap the ground onto the pipes? Some installers don't even tap the ground wire.
February 17th, 2020 08:39 AM #115
February 17th, 2020 09:02 AM #116
February 17th, 2020 09:22 AM #117
Fusion welds on way thicker PPR vs PVC glue. Longevity & pressure/tension thresholds. When done right, PPR joints have greater chances to be leak-free from the get go & would remain so. PVC more hit/miss + w/ constant water hammering, they can leak after a while.
February 17th, 2020 09:46 AM #118
PPR are rated for much higher pressure vs PVC. I use them for high pressure air lines.
- Jul 2013
- 2,450
February 17th, 2020 09:51 AM #119Boss, sorry for asking you this. Our rented house (an old one like more than 50 years old hahaha) is modeled after an American house (much like the rest in the neighborhood).
Kaya naman ang mga socket namin ay 240V at 120V sa isang outlet (in pairs yan). Problema is yung normal plug natin yung 120V haha. But DIY guy naman ako so kinonvert ko sila sa 240V and during the process napansin ko nga yung 3 wires. Yung 2 wires ay 120V each at isang ground wire.
How do they do make wire? Additional cost ba ito kung magpapagawa ka ng bahay tapos may ground wiring all over the house.
February 17th, 2020 10:14 AM #120
In this case, just identify the specific outlets where you'll plug your appliances that ideally need grounding.... like heaters, ACs, fridges, kitchen equipment, etc. Have your electrician route an earth line for those to save on cost.
Tesla Philippines
