Results 11 to 20 of 22
November 20th, 2012 01:17 AM #12
November 20th, 2012 07:21 AM #13
Yep. Read-write endurance is a fact of life for SSDs. Unless you are writing huge amounts of data to and from the drive though, the usable lifetime of an SSD is a non-factor for most consumers.
Unless you're running Windows XP or lower, it shouldn't be a problem. There is an onboard "TRIM" command that balances the wear between the NAND flash memory cells on an SSD. Many SSD makers have their own optimization software to go along with their products too, such as Samsung's Magician and Intel's SSD Toolbox.
In my case, Intel made up for the lack of the TRIM command on XP via its maintenance software.
There is one thing you do have to avoid: Do NOT defrag an SSD. That has no benefit and just prematurely wears out the NAND flash.Last edited by Type 100; November 20th, 2012 at 07:24 AM.
November 20th, 2012 09:10 AM #15
November 20th, 2012 11:34 AM #16
November 20th, 2012 02:06 PM #17
as others have said, until SSD prices go down and capacity improves the traditional platter-based HDDs are not going anywhere.
November 20th, 2012 09:07 PM #18
Not anytime soon, but it could happen.
As the process node lithography of NAND flash memory goes down, you can cram more memory into a given piece of silicon. This is the biggest reason why SSDs have gotten much cheaper over the past four years. You're essentially getting more yield out of the same amount of raw material.
To give you an idea, my Intel X25-V back in 2010 was made on a 34nm lithography process. These days the newest SSDs are approaching 25nm, 21nm and even 19nm NAND.
November 20th, 2012 10:12 PM #19
November 20th, 2012 11:02 PM #20
Tesla Philippines
