Page 20 of 30 FirstFirst ... 10161718192021222324 ... LastLast
Results 191 to 200 of 296
    Nov 2019
    #191
    When I speed test on mobile, I only got 33 MBPS speed.
    However, from PC, I got 100+ MBPS, bakit may discrepancies result ng mobile vs PC?
    Both are connected on a same router.
    Ano tong 100MBPS boost speed until April 30?
    #192
    Quote Originally Posted by carxynogen View Post
    Are you using a 2.4GHz wifi connection or a 5GHz connection?
    Sample test from the same wifi router connected to a 100Mbps plan but on different wifi connections.
    2.4GHz connection
    5GHz connection
    Nov 2019
    #193
    Quote Originally Posted by gls2001 View Post
    2.4GHz connection
    5GHz connection
    May difference nga, but as of today, 2.4G result is 70MBPS.
    While 5G result is 100MBPS
    Jun 2015
    #194
    PLDT Fibr seems to be down in Las Pinas. Red LOS since this morning.
    #195
    ^ Working good naman from where i'm at.
    #196
    Monday test[emoji108]Click image for larger version.
    Sent from my BL6000Pro using Tsikot Forums mobile app
    Mar 2004
    #197
    There are times when workers damage the fiber cable on the post(s) you're connected to ...
    Feb 2018
    #198
    Nagpost friend ko yesterday. Las Pinas area din, down daw
    Jun 2015
    #199
    Must have been confined to Barangays Talon Dos to Pamplona.
    Connection was back to normal when I woke up this morning.
    #200
    meron na dito nagkabit ng netgear wifi extender dito?
    install ko sana pero ayaw umilaw ang wps ng router ko pag pininipindot ko. iyong sa netgear ayos naman. so ang tanong naka-disable ba ang wps feature ng mga router natin? or busted iyong router ko or kelangan ng adjustment from pldt's end?
PLDT Fibr
