Results 21 to 30 of 400
August 6th, 2012 11:12 AM #21
Last month, a few things happened at home. I bought a large-screen LED TV and a 5.1 home theater system. That was also the same month I replaced most of our CFLs with LEDs.
For me, it's all about diverting electricity to the cool "stuff". You can look at it in a way that you can add more appliances at home without your electricity bill breaking a spot of sweat. So, even with the addition of the big TV and HT, my bill came out about half a grand cheaper than in June.
To put things into perspective, the CFL bulbs I replaced had a cumulative wattage of about 234W. The LEDs that replaced them have a cumulative wattage of only 66W. That gave me around 168W to play with. The HT+TV uses about 115-125W at the outlet (LED TV ftw!) and needless to say, I still have change left.Last edited by oj88; August 6th, 2012 at 11:17 AM.
BANNED BANNED BANNED
- Jul 2003
- 2,267
August 6th, 2012 11:17 AM #22
August 6th, 2012 11:21 AM #23
^^^ Good for you, bro.
I'm still waiting for the economies of scale to kick in.... (It will, sooner or later)....
16.5K:weathermanf3:
August 6th, 2012 11:41 AM #24
^ same here, at home we rarely have lights that is used for more than 8 hours per day. Will wait for cheaper versions for the 8 hour lights.
August 6th, 2012 12:12 PM #25
August 6th, 2012 12:26 PM #26
I'm with CVT I'll just wait for it na bumababa, if I'll replace all the CFL in the house mamumulubi Ako, Sa master BR pa Lang 14 pin lights na, hinde pa kasama Sa CR and closet...
Sent from my iPad using Tapatalk HD
Tsikot Member Rank 4
- Jun 2006
- 2,605
August 6th, 2012 06:13 PM #27Yes lumens is the more accurate way to compare brightness. But, cdrking did not post the lumens they just said its about equal to a 40 watt incandescent bub so its a fair comparission.
CDR KING
And their warranty is 1 year with 1 week replacement.
I just bought 2 Osram bulbs. A 2 U cfl 13 watts rated at 805 lumens P99.00 at Ace Hardware and a 18 watt spiral rated at 1166 lumens. Thats what the dti sticker says. I dont know why you find the LED brighter than the 20 watt spiral. I'm guessing its due to the age of the spiral cfl. CFLs tend to loose brightness as it ages. I forgot the term for it. LEDs do not suffer from this.
August 6th, 2012 06:18 PM #28
- Jun 2006
- 2,605
August 6th, 2012 06:21 PM #29You are correct. That was my mistake. My roof was too low so heat transfer was awful.
Can you pls post the lumens of the LEDs. It will help us compare them to cfls. From my understanding. CFL is about 5X brighter than a incandscent bulb while LEDs are 10X brighter. Meaning a 20 watt CFL is roughly equivqlent to a 100 watt bulb while a 9 watt LED is about equal to a 90 watt bulb. I know there are a lot of other factors to consider such as reflector, color, temp etc... but as a ball park I think it will do.
If anyone knows a cheap source for LEDs to replace FL bulbs, I'm interested in buying. Need to save.
August 6th, 2012 06:22 PM #30
For me the savings will only be realized If you replaced all your existing bulbs to LED.. Pero naman you'll be spending a big sum of money still not worth it
