Results 11 to 20 of 26
Tsikot Member Rank 4
- Jun 2006
- 2,605
October 22nd, 2006 09:40 PM #118 cell. model is pb993a interchangable with pb993ut. I think its the same battery with different model numbers.
October 22nd, 2006 09:48 PM #12
price is reasonable naman, batteries for non-branded units costs around 4 thousand na rin eh
November 2nd, 2006 07:52 PM #13
what's the usual battery life of an ordinary laptop bat? would it last a year or 2?
November 2nd, 2006 08:12 PM #14
it would go around 2 or 3 years under normal use... the most i've experienced is 4 years...
- Oct 2005
- 51
November 2nd, 2006 11:17 PM #15Sir tanong ko lang pano ba alaagaan ang battery ng laptop para di agad masira kasi yung akin wala pang 1 year mula nung binili yung laptop di na nagchacharge yung batt ko
kaya lagi na lang nakasaksak pag ginagamit ko di ko tuloy maenjoy pagiging laptop nito. thanks po
November 3rd, 2006 12:03 AM #16
sa market market at festival mall may nag rerepack daw ng battery
di ko lang alam kung magkano,mapasyalan nga pag nag loko na ang Batt ko
- Jun 2006
- 2,605
November 3rd, 2006 10:19 AM #17Less than 1 year baka naka warranty pa yan. Check mo sa binilihan mo. Kung wala na sa warranty, try mo www.inkplaza.com.ph they repack laptop batteries.
November 3rd, 2006 12:36 PM #18
here's a good additional read regarding laptop batteries...just came across this kanina:
http://www.mobilityguru.com/2006/11/..._they_blow_up/
November 3rd, 2006 12:40 PM #19
use the battery the way you used your cellphone and charge it once the low bat shows.
madalas kasi laging kasaksak sa on line power pag nasa office tayo. this is one cause to disharged and shorten the battery life.
suggestion,if you are using on line power and laptop showed the battery is fully charged, try disconnect battery while using on line power.
