Results 31 to 33 of 33
August 30th, 2022 02:52 PM #31
Bought this keychron k4 v2 last week. I've been using a full qwerty keyboard and adjusting to this kind of configuration is a bit learning curved.
I replaced the arrows with this red PlayStation buttons to give me a visual cue where the arrows are, it also helps separate the num pad.
Also ordered keycaps from shopee that will group the keys with different color schemes para Mas madali ma distinguish. Especially the function key, the keycaps I ordered will give F1 to F4 a different color from F5 to F8, and so on. Sa full qwerty kasi separated ang function keys in 4, kaya madali. The new keycaps would also help distinguish where the function keys end and the delete key begins.
This keyboard is shorter than the full qwerty so now my mouse has a wider movement stage.
The switches are gateron brown, currently satisfied with it. Nung nanood ako sa youtube dami pala varients ng gateron, will probably try other variants pag sinipag mag customise.
- Mar 2014
- 694
August 30th, 2022 03:13 PM #32I started sa full-sized mechanical keyboard (Filco Majestouch 2) then switched to tenkeyless (Magicforce 68) then 60% (Anne Pro 2). Though pwede gamitin yung ibang keys ng Anne Pro 2 as arrow keys, iba pa din talaga may dedicated arrow keys so I bought and still using Skyloong SK64S (64 keys using optical switches). Changed the stock Gateron brown switches to Gateron red as well as keycaps.
Been using brown switches ever since pero last year, sumasakit na fingers ko after using it for work or gaming so I tried red switches which has been a good change for me.
September 5th, 2022 01:05 AM #33
