Page 2 of 8 FirstFirst 123456 ... LastLast
Results 11 to 20 of 78
    sige, try ko after ng mga downloads ko. thanks.
    May 2005
    *ian_rex
    thanks! yung mga folders ko, no access limitations naman lahat. Although yung desktop ko is Windows Pro, yung laptop ko is windows home. May effect kaya to?
    Jan 2004
    *laklak, i don't think so. pero na-try mo na bang ilipat yung files mo sa shared folders? di pa ako naka-subok magkaroon nang ganung problema kasi pag nagta-transfer ako mula desktop to laptop or vice versa ok naman e.
    May 2005
    ah yung sa shared folder ng windows mismo? kasi ang ginagawa ko is niriright click ko lang yung folder then sharing options na eh. Anyway, ill try that option first.
    Jan 2004
    *laklak, sige try natin. ako di ko pa din na-try kasi nung nag-transfer ako nang malalaking data, direct e. nakawireless ka din ba?
    Apr 2003
    by default dynamic ip naman ata yung linksys router, is it not? if you plug in smartbro to WAN then connect your pc to the LAN port, you don't establish a network connection?
    smartbro din ako. sayang lang nga yung additional router in this setup. Just sell the wired router for other upgrades.
    may existing wired router na kasi ako, kaya i-configured the wireless router to act as an access point for my wifi devices.
    sinubukan ko din ikabit direct yung smartbro sa wireless router, pero wala akong nakitang option na dynamic ip dun sa setup ng linksys kaya binalik ko ulit as access point nalang.
    Jul 2006
    sir kung ganun ang setup mo... mas better na router ang linksys... dlink sucks big time as a routing device... saka lahat ng routers defaulted to dynamic IP or you are using a DHCP server to provide dynamic IPs... baka sa naming convention lang nag iba kaya di mo napansin...
    Jan 2004
    tama sila. last time i checked, there is a setting "Automatic DHCP" for dynamic IP. i overlooked this one when i was setting up a linksys router too. decieving din kasi yung installation instruction ng linksys. on my netgear, i haven't encountered that problem. that's why i got connected in less than an hour- inulit ko pa yun. we'll wait for boybi to post what he's got
    for me, i wouldn't sell the other router, but will reduce it as a switch only. especially for the far-off desktop. i think the reason why he bought the linksys is to have an access point for his wireless connection. i may have read it somewhere here in tsikot:
    http://tsikot.yehey.com/forums/showt...t=28975&page=4
    just scroll down. anyways, hope that he got connected already.
    i also overlooked the Automatic DHCP. first choice kasi ito sa drop down list, and hinahanap ko kasi specifically yung Dynamic IP. try ko later i-setup.
    May 2005
    Quote Originally Posted by ian_rex View Post
    actually wala namang problema sa pag transfer ng isang malaking file eh, lumalabas lang pag medyo madami ng lamang files yung isang folder tapos over 1GB na yung folder size. Wireless din ako.
Home networking, help.
