Page 9 of 96 FirstFirst ... 56789101112131959 ... LastLast
Results 81 to 90 of 954
    Jan 2009
    #81
    Tried a different mouse on the computer and cursor movement was normal.
    Tried the mouse on a different computer and it's still reversed.
    Too bad; gaming mouse pa man din ito that I got as an exchange gift.
    Gaming mouse? It may have a switch, either a physical switch or software-controlled that will reverse the axis.
    Jun 2015
    #82
    Sadly, no such switch.
    The button programming software doesn't even detect it anymore.
    Also, this mouse used to work fine as plug and play. Its software's only purpose was to assign different operations to the buttons (X-mouse was way better IMO).
    Sakasa mouse is an option but it's more of a prank program and doesn't work consistently.
    Jan 2016
    #83
    Mga paps, ano kaya tawag sa usb adapter Ng internal hdd na sa right, the one with the bracket, kasi ung old ko are pins, this new one is already embedded on board, papa repair ko kasi laptop so I need to retrieve and wipe the data inside. Thanks.Click image for larger version.
ID:	35650Click image for larger version.
ID:	35651Click image for larger version.
    Mar 2005
    #84
    SATA - Yung old one is IDE. (pins) Any external drive enclosure nowadays are sata based.
    PATA on the left.. SATA on the right.
    PATA or EIDE .. 80pin ribbon cable.
    Jun 2015
    #86
    You can plug that small hard drive (the one on the right) to any desktop with SATA if all you want is to access it one time to clean up.
    Sent from my Nokia 6.1 using Tapatalk
    Jan 2016
    #87
    Thanks mga paps, I saw it na sa shopee, SATA na nga ung new, IDE pa ung old ko
    #88
    Anyone know a cheaper place to buy laptops in Southeast Asia than Hong Kong?
    I'm currently eyeing this HP Envy X360 (Ryzen 7, 16GB RAM, 1TB SSD, 13" FHD) selling for 65k in HK:
    I've checked locally and the closest they have at this price point is an Envy X360 with a Ryzen 7 CPU but only 8GB RAM and 256GB SSD for 63k.
    I also checked Singapore prices and it's only about 3k cheaper than PH for the same specs. I don't wanna buy from the US because it's harder to claim warranty unlike HK/SG where I have friends flying in and out monthly.
    #89
    Honestly? I've avoided HP laptops like a plague. I stick with ASUS and Lenovo for regular laptops or Sager (Clevo) at the top end.
    #90
    +1. hp are good only on laser printers and imaging devices, Laptaps and afterservice are quacks. Personally i'd get Lenovo, Dell, Acer, Asus.
Computer and Laptop Tech Thread
