Re: Computer and Laptop Tech Thread
Hahahahahahahahahah
Quote:
Originally Posted by
EQAddict
Finally after 3 months...my warranty replacement of my defective memory was honored By Dynaquest. Grabe sobrang hassle to get warranty honored.
2x16gb 3600 mhz gskill rgb ram.
That's poor service ...
BratPAQ
I just ordered from shopee tecware panthom L. Outemu blue sya. I choose it because I miss the keyboard of the 90s na clicky and solid ang feel. May software din daw ito na pwede download to configure the lights. Ayoko kasi iba't ibang kulay na ilaw. I browsed that thing about cherry. Na overwhelm ako sa dami into. Maybe instead of reading I should watch YouTube comparison.
You can change the lights sequence, speed, and colors using keyboard shortcuts ... Got same keyboard, swapped 2 broken keys already, it's not so sturdy for gaming and that's just occasional play ...
Walter
Broken switch? Where did you get the extra switch?
BratPAQ
Our Rakk Ilis came with two extra Outemu Blue switches. Kung walang kasama you can swap with a seldom-used key like one of the F keys. Unang bumigay ay yung A and D kaka-FPS.
Yung Cherry Red ko nagloko din ang D. Nilaksan ko lang ang pindot ilang beses umayos naman.
Yan ang advantage ng mechanical. Most common switches are available online.
https://uploads.tapatalk-cdn.com/202...a3998313f8.jpg
Logitech X56 finally went back in stock! Excited for the weekend!
Excited pa naman ako sa RTX 3070 tapos positive ang paper launch/announcement ng RX 6000! Sana ok reviews from tech reviewers and ok ang drivers this time. Every forum na basahin ko lagi nalang may reklamo sa Radeon GPU drivers. Will wait it out and magtiis muna sa GTX 1070ti ko. Magdepende din kasi ako sa new GPUs na to kung anong monitor bibilin ko (gsync or freesync with gsync compatibility).
marky2115
The radeon 6000 wil utilize ryzen 5000s memory. Well find out soon enough if the performance suffers with the older cpus.
Nice flight controllers
EQAddict
Thanks! It’s been really difficult finding a seller with stock. I pre-ordered the Thrustmaster TCA Airbus HOTAS but it kept getting delayed. Luckily I found this set.
