Re: Computer and Laptop Tech Thread
Quote:
Originally Posted by
jut703
Not a software issue. Have already checked everything you mentioned.
I seem to have found the issue though - I'm constantly hitting the 100 deg C limit of my processor at max load so it throttles down and thus hampers performance:
https://uploads.tapatalk-cdn.com/202...bd84620982.jpg
Solution: Undervolting via Throttlestop. 90mV undervolt on the processor and 30mV on the GPU. My temps dropped by an average of 10 degrees even at full load:
https://uploads.tapatalk-cdn.com/202...fd14ab111a.jpg
Laptop now keeps at higher Turbo Boost for longer, even maintaining peak clock speed of 4 GHz.
Was gonna reco throttlestop if high temps were found. 15w(ish?) cpu and its still overheating. It could be the thermal paste. I got some tools and thermal paste for a laptop upgrade for one fam member.
StockEngine
Yan yung nuclear option ko - change the thermal paste. But I would assume an X1 Carbon would be well-built enough not to need thermal paste replacement in less than 2 years.
Thankfully nasolve ng undervolting. :)
Got a new upgrade of PC.
AMD Ryzen 7 3700x
Msi B550 Mortar
Samsung 511gb ssd
WD 2tB HDD
kulang pa ng parts, as delayed ang deliveries.
Pang light task lang and some gaming
Sent from my SM-A507FN using Tapatalk
jut703
If you want you can borrow the tools and have some arctic mx4. Dropby lng sa flair.
jaggerx3
AMD Ryzen 7 3700x
Msi B550 Mortar
Samsung 511gb ssd
WD 2tB HDD
Excellent board choice:bowako:
jaggerx3
AMD Ryzen 7 3700x
Msi B550 Mortar
Samsung 511gb ssd
WD 2tB HDD
How much abutin ganyan setup? Kaya ba nyan ang MS Flight Sim?
boybi
Kaya naman.
Basya goods GPU pati RAM.
Namimili pa ako ng GPU pero I'll go with Nvidia over AMD GPU
StockEngine
Future proof na [emoji16]
Ngayon lang ako ulit nag AMD after 14 years siguro.
Atlhon 64 last na AMD ko, tapos Intel na.
Pentium 4, Dual Core, Core 2 Quad, i3, i5. Then eto ngayon Ryzen.
Susprised that they had this type of CPU na.
boybi
Needs video card to run flight sim. Add 20k to this build to run flight sim with a RTX 2060
StockEngine
x570 board? which psu? all from mwave?
scorptech yes x570 gyga gaming x..
specs
gyga x570 gaming x
8gbx2 corsairs
r5 3600
650w HX corsair
LianLi 011d
lian li fans
corsair rgb xt 360
500gb samsung m.2 nvme
currently on 285gtx ...still waiting on 3070
