Results 11 to 20 of 30
Tsikot Member Rank 4
- Jan 2003
- 1,403
June 18th, 2009 10:26 AM #11
- Jan 2003
- 1,403
June 18th, 2009 11:53 AM #12Called PC Clinic in Pasig. The guy said I have to leave the printer for 3 days because they have to burn-in the printer after repairing it. I know burning in computers is part of the Q.A process. But burning in printers? The guy said that is because it has a heater and fuser.
First time I heard about this. Told him I will get back to him.
Damn. I didn't know getting a laser printer repaired can be this difficult. Maybe I ought to just buy a new one.
June 18th, 2009 12:18 PM #13
I used to be HP-certified to repair hp laserprinters and we never had to "burn-in" a printer. We usually mention "observation" because we might have to do a few extended print tests or the problem might be intermittent (but for laser printers, it either works or doesn't work). Example was the early color laser printer which showed an error
Even our office HP1010, the right side suddenly became smudged in every print out. I checked the printer and the heater's teflon roller has become damaged & torn. Good thing I had another "defective" HP1010 (sensor error in the fuser assembly & spare part would cost more than the value of a new current model laserjet unit) and salvaged the teflon roller from that unit.
June 18th, 2009 03:19 PM #14
Just buy a new one.
I had an HP 1000 and 1100 before. It's a terrible printer when you need bulks printed because it keeps having paper jams.
I disassembled it in an attempt to find out what is wrong with it. Apparently, it's the design. I got sick of it so I didn't bother putting it back together anymore.
I just bought a Konica Minolta. 3yrs Warranty on everything including the drum and toner.
But I recommend you get Kyocera. Drum is rated at about 300K pages before replacement. Some models, AFAIR, have lifetime drums (ceramic).
June 18th, 2009 05:02 PM #15
June 18th, 2009 05:22 PM #16
Mine was with HP, Cattleya and (A something brand) 80gsm paper, I usually buy in reams because it's cheaper. The problem arises from the design of the feeder roller guides. They should have used three, not one.
I never had the same problem with Kyocera (1030DN) nor Konica Minolta (Bizhub 600 and PagePro 1350).
June 18th, 2009 06:09 PM #17
- Jan 2003
- 1,403
June 19th, 2009 09:17 AM #18
- Jan 2003
- 1,403
June 19th, 2009 09:33 AM #19Buying a new one is definitely an option if I can't get the printer repaired for under P1,000 since new lasers are just P4,500 to P7,000. I don't need a heavy duty model since I only do light printing. I try to maintain a paperless office, albeit obviously still quite unsuccessful.
I know there are a lot of good alternatives but I have always been partial to HP lasers since they have generally not given me any problems including toner cartridge availability.
OT Trivia - Kyocera used to make ceramic automobile engines. Not sure if they still do.
June 19th, 2009 09:41 AM #20
Tesla Philippines
