Results 11 to 20 of 22
February 6th, 2012 07:55 PM #11
Pag double decker kailangan pag sakay bayad agad, mahirapan maningil ang conductor niyan
February 7th, 2012 10:26 AM #12
A half-empty single bus is losing you money every minute it's on the road and burning diesel to run the airconditioner.
But a half-empty single bus will be losing less money than a three-quarters empty articulated bus. Two half-empty single buses would be losing more, but when you have two, you can garage one and just run the other. Makes for more flexible operation.
I like double-deckers... upper deck is fun... but they're not going to fit on our roads.
February 7th, 2012 11:09 AM #14
Now let's see that fit underneath a pedestrian overpass.
February 7th, 2012 01:00 PM #15
February 8th, 2012 11:41 AM #16
Usual height of a double-decker is between 4,2m and 4,5m. But the ground clearance is not so high as you can see in that old picture, comparing the Leyland DD with the Hino Blue Ribbon and that yellow bus I didn't know the bodybuilder.
February 8th, 2012 12:20 PM #17
there are reasons why bus operators here do not use double deckers and extended buses
if double deckers and extended buses are applicable here (and profitable) they would have used them already
it's not as if buses operators here don't know double deckers and extended buses exist and that somebody has to introduce those kinds of buses to themLast edited by uls; February 8th, 2012 at 12:23 PM.
February 8th, 2012 04:44 PM #18
I would wager 4.2 is the one without a roof? Roofless won't work here in the Philippines.
4.5 meters is too high. Minimum clearance to overpasses on major highways is around 4.2 meters (EDIT: internet check... 4.27 meters, actually). On minor roads, you're lucky to even get close to 4 meters of height clearance.
February 9th, 2012 07:43 AM #19
