Results 11 to 16 of 16
- 170
October 18th, 2002 07:07 PM #12
wow booster huh... the 2psi made a lot of difference? can you enlighten me more on this ser yellow.
seems pretty interesting
- 170
October 18th, 2002 07:16 PM #13Dakila7,
As of now I was able to increase 2 PSI with 4 pieces of washers, how would you like me to enlighten you? Just ask questions. I'm still monitoring how it's affecting the engine, so far it's been a week that i've set the turbo this way, I'm observing how it's affected gas consumption, acceleration, top speed and temperature of the engine. so far I could feel improvement on the acceleration.
- 170
October 18th, 2002 11:17 PM #15pajerokid,
No problem I just had a full tank yesterday so I'll be able to see whats the consumption by next week, so far I could see normal pace driving at second gear, maybe around 2,000 rpm before i put the washers i had 2 psi of boost now its around 3, so i guess there is an improvement in the lower rpm range. but the mod is felt at the higher rpm band of the engine.
Maybe if you have a heavy foot you'll consume more diesel, with the higher boost now the injection pump compensates earlier to give more fuel for the higher boost. I'll try to take some pics this weekend, post your email add so I can send it to you.
October 19th, 2002 02:51 PM #16
thanks so much sir yellow
please send them to mann2*i-manila.com.ph
thank you thank you thank you!!!1
