Page 7 of 10 FirstFirst ... 345678910 LastLast
Results 61 to 70 of 95
    #61
    kabit ka lang washers, u don't need a boost gauge na unless u want to install a manual boost controller then ul need a boost gauge, ako kinabit ko 4 na washer n u will feel the difference. but don't expect a lot ha. the diesel consumption is not noticeable.
    Jan 2003
    #62
    KCboy,
    "4 washers " -as in 4 washers each side? Any washer ba? Baka kasi iba kapal or baka malagay ko madali kalawangin, hehe..
    Thanks!
    CLARIFICATION, am I supposed to place the washers below the "can" that was removed in the pic? thanks again.
    Aug 2006
    #63
    yung samin mga 2500 rpm bago mg boost ng 5psi gs2 ko ko itaas boost and add blow off valve khit diesel it rocks hahaha
    #64
    *carnovice: walang problema kahit kalawangin yan. any washer that will fit will do. basta 4d56 max pressure is 12psi. some people say they even reach 30 psi. but manuals clearly says 0.83 bar/3000rpm
    kung 30 psi ang mitsu, talo pa ata nila ang newest BMW diesels na 27psi lang... Ford Focus Diesel nga, 14 psi max lang...
    installing the boost guage is the easiest part. you will just hook a extension 'T' in the boost hose line.
    Aug 2006
    #65
    sir rion ok po ba kpag nag 15psi kasi po misan napapaabot ko dun eh..kapag long driving ok lang ba ito pero i do oil change every 3 months
    #66
    sorry, I don't know adventure. I don't even know if changing oil often will help. does it?
    but in my opinion, hindi siguro ganun ka grabeng masama sa 4d56, kasi maraming nag sabi sa Pajero uk forum na umaabot 15 psi sila... baka matibay nga 4d56...
    but don't take my word for it. kasi as for our Pajero 4d56, 12 psi lang ang max na bigay ko. mahirap na kung magkamali...
    Aug 2006
    #67
    *sir rion
    sir nalinis niyo na po ba yung intercooler niyo kasi gusto ko pong linisinbaka po madumi na yun kasi 7 yrs na walang linis yun and gusto ko po sana gawin yung washer mod... ano po ba ang mangyayari dun sinabi na din po nung uncle ko sa akin yun eh lagyan daw ng flat washer para lumakas daw yung boost.At ok po ba maglagay ng blow off valve,,pinaplano po kasi namin yun kaya lang walang space,,,And kailangan po ba talaga ang BLOW OFF VALVE gusto ko lng po dito yung tunog pssttt.....tutunog din po kaya sa diesel engine na ganun heheheh para san po ba ito????
    #68
    Quote Originally Posted by adventure View Post
    *sir rion
    yep, nalinis ko po recently. didn't feel any difference though... saan po ilagay ang flat washer? aside between the wastegate and turbo?
    hindi pa po ako nakalagay ng blow off valve. sorry. but I'm intested though, do you know where can we buy them and how much?
    but I hear Turbos has a silencer ring. lalakas yung tunog kung tangalin mo. but I haven't checked our 4d56t though.
  9. #69
    rion, may thread ata dito about sa washer mod for 4d56t..
    #70
    * AY: yes, I want to clarify what washer is adventure talking about?
    aside from the washer mod we install between the turbo and the wastegate.
    Edit:
    * Adventure: your uncle talking about "flat washer" is the same with tiskot's "Washer mod" pala...
    you got me confused there...
    but wait... I thought your 4d56 gets 15psi already? so you haven't washer mod it yet?
    is your ride adventure with a pajero engine? or a adventure fitted with turbo? baka may problema wastegate mo.
    I'm still interested in bov. it's a Rice I'm interested to make... it could be useful too, I'm actually getting boost spikes readings after the washer mods.
    I driven once a vehicle with a loud turbo kasi eh... I just love it when it shuts the engine off... parang eroplano shutting down engine sound...
how to increase  power of 4d56?
