Results 31 to 40 of 41
- Jan 2005
- 30
January 13th, 2005 11:18 PM #32
Glow plugs are used only to preheat the fuel prior to starting. If your engine is smoky, check for any gasket leaks.
Check also your thermostat if it is allowing the engine to reach optimal temperature.
If the engine is smoky only when cold, then you can pass it off as normal.
January 15th, 2005 07:51 AM #33
Originally Posted by KCboy
I agree with KCboy... just encounter this problem late 2004 and iniwan ko talaga yung Pajero para ma test ng mechanic sa umaga. And later on they found out that the problem is with the relay.. So binaklas lang nila and konting linis and ayos 1 click uli yung Pajero.
it's not always the glow plugs..
January 15th, 2005 05:01 PM #34
we also experienced hard starting on our pajero pinalitan din ang glow plugs as adviced by the mechanic. after a year or so, the old sickness occured. siguro we heat the plugs three times before we start it.
napapansin ko rin medyo bluish na ang smoke that it emmits after starting. is it a sign that that the injectors needs to be calibrated?
January 17th, 2005 10:34 AM #35
Ok na ang L300 ko!
Ang ginawa niya lininis niya ang injection pump with repair kit, ngayon ok na. Wala ng usok at saka smooth idle na sa umaga.
Ok lang ba na e advance niya yung timing ng Injection Pump? kasi sabi niya para daw masmalakas. At manual lang ang ginawa niya sa injection pump walang machine, or kailangan ba na ecalibrate with machine ang injection pump.
per as of now ok naman yung ginawa niya, smooth and no white smoke pag umaga. pero enad vance lang yung timing. ok ba.
January 17th, 2005 08:20 PM #36
sir acenie im experiencing the hard starting po evry morning.. hehe.. san nyo po pinagawa yan? and magkano po? tnx
January 18th, 2005 10:01 AM #37
Kung Hard Starting! e check mo yung Glow Plugs baka may dead na. kung ok e palinis muna na yung injection pump. Gastos ko lahat is 1400, 600 ang labor injection repair kit 800. Tapos tope and check lahat ng belts with oil seal change. Dito sa amin Laoag.
January 18th, 2005 09:10 PM #38
tnx po.. changed the plugs napo eh.. wala improivement.. hehe try ko din yan.. hehe
- Jun 2004
- 476
January 19th, 2005 01:26 AM #39Originally Posted by acenie
January 19th, 2005 11:49 AM #40
ok naman yung ingay! pero hindi kaya masmalakas sa Diesel kung advance timing?
Tesla Philippines
