Page 9 of 13 FirstFirst ... 5678910111213 LastLast
Results 81 to 90 of 124
    #81
    I disagree...
    Kapag likod ma-flat, mas madali icontrol yung car.
    Sa harap, biglang kakabig yung car sa direction ng flat tire.
    Wag ka lang biglang mag-brakes...
    Okay, suit yourself. Take care on the road.
    Which is more dangerous, bursting a front tire or the rear one? - Updated - Quora
    #82
    i'd put the thicker tires in front
    Thicker tires should be in the front if ever the tires are for replacement already.
    https://m.tirerack.com/tires/tiretec....jsp?techid=52
    However, if the front tires have significantly more tread depth than the rear tires, the rear tires will begin to hydroplane and lose traction on wet roads before the fronts. This will cause the vehicle to oversteer (the vehicle will want to spin). Oversteer is far more difficult to control and in addition to the initial distress felt when the rear of the car starts sliding, quickly releasing the gas pedal in an attempt to slow down may actually make it more difficult for the driver to regain control, possibly causing a complete spinout.
    6 Common Tire Myths Debunked
    2. When replacing only two tires, the new ones go on the front.
    The truth: Rear tires provide stability, and without stability, steering or braking on a wet or even damp surface might cause a spin. If you have new tires up front, they will easily disperse water while the half-worn rears will go surfing: The water will literally lift the worn rear tires off the road. If you're in a slight corner or on a crowned road, the car will spin out so fast you won't be able to say, "Oh, fudge!"
    There is no "even if" to this one. Whether you own a front-, rear- or all-wheel-drive car, truck, or SUV, the tires with the most tread go on the rear.
    Should you fit new tyres to the front or rear?
    CONCLUSION
    To give the best possibilities of a vehicle handling safely when fitting new tyres to a vehicle in pairs, it is advisable to fit the new tyres to the rear axle.
    Mixing Tires | Using Different Tires | Michelin US
    If only two tires are being replaced, Michelin generally recommends they be installed on the rear axle in the absence of a tire service professional's recommendation or consumer's preference to the contrary.
    #83
    As I understand that is if you realky need to replace the tires. But if not yet for replacement. No problem putting a new tire in front.
    I could be wrong though.
    Sent from my LG-H990 using Tsikot Forums mobile app
    #84
    For Front Wheel drive cars, put the new tires up front. Since those wheels do the driving, braking & steering at the same time
    nalipat ko na ung makapal sa harap eh
    so papalitan ko nalang ng 2 bago ung likod
    tatapon ko na ung 2 manipis
    madali naman ako kausap eh
    hehe
    Sep 2012
    #87
    Meron na ba sa inyo na naka Duraplus na more than 80,000 na naitakbo?
    Goodyear DuraPlus - GOODYEAR
    Sent from my ASUS ZenFone 4 using Tapatalk
    #88
    hehe
    Kotse itapon mo. [emoji51]
    Jan 2016
    #89
    Ang galing! apat agad ang claim nya at hindi sya halata ng dealer, o pa isa isa tapos iba ibang dealer hehe...
    In my case... Depends kung sino and saan ginagamit yung car...
    I know someone from Melbourne (I have a lot of stories from this guy since wais sya sa buhay... better term is magulang)
    He bought a tire from a reputable service centre with warranty... Before the warranty ends, I-run flat nya konti yung tire para mag karoon ng side wall damage...
    Tire gets replaced and the new tire will have a warranty again, same procedure later...
    Jan 2016
    #90
    What I don't understand is the practice of replacing 2 tires only per time. Sa kumpanya ganyan and I never questioned that practice for as long as palitan nila ako ng gulong.
When Do You Replace Tires?
