Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
    #21
    In addition, ang mga coolant may difference, mga extended life usually sa aluminum radiators, ang mga "older" coolants sa copper, di sila pwede paghalo otherwise namumuo sa metal surface or nagpropromote ng corrosion.
    Mar 2005
    #22
    Quote Originally Posted by theveed
    Yeah, as I posted earlier:
    Results of industry standard tests of the new Toyota extended-life (PINK) coolant now show a substantial weight loss (corrosion), both in a 50-50 mix and in a 33% coolant mixture (solder corrosion is much greater in this more diluted solution).
    Apparently the new Toyota Coolant (PINK) doesn't adequately protect against solder corrosion on our soldered brass/copper radiators.
    Dec 2002
    #23
    What about "Peak" brand coolant, is this compatible with jap cars? I've used both the concentrate and the pre-mixed one in our cars.
    Aug 2004
    #24
    Quote Originally Posted by Psylocke
    raikonen,
    ha meron pala sa Toyota Cab? Gago talaga yung tao sa parts dept! Sabi nya wala na! Mali pa yung price na sinabi nya, 189 daw!
    yun din una ang binibigay sa akin but i insisted on the RED one... checked my receipt again and it's 198 nga..
    Mar 2005
    #25
    Quote Originally Posted by raikonen
    Nadaan ako sa Pampanga kaya dun nalang ako bumile sa Toyota San Fernando...
    #26
    newer models pala ng toyota like the previa & innova, doesn't require replacement of coolants until 100K kms! and also the spark plugs, 100K kms din daw ang interval.
    Signature
    #27
    eto toyota pink coolant and absolute distilled:
    nung nag-flush ako ng radiator sa 2000 Revo namin last year, after ilang months nabutas radiator hehe.. pwedeng tsamba, pwedeng hindi.. hindi ko talaga alam ang cause..
    Mar 2005
    #28
    Quote Originally Posted by boybi
    AFAIK 2004 and later come pre-filled with the PINK extended-life coolant. The organic acids deplete very slowly and can last up to 5 years.
    Mar 2005
    #29
    Quote Originally Posted by revoGSX
    Hmmm... baka nga yung pink coolant...
    Mar 2005
    #30
    Where do you guys dump your used coolant?
Toyota Red vs Pink Coolant...
