Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 39
    #21
    Quote Originally Posted by grand kotse View Post
    Guys ano kaya ang problema yung isang gulong ko hindi naman sya flat at matigas naman sya pero ang pressure nya ay 22psi lang. Nilagyan ko sya ng hangin at parang mas matigas pa sya compare sa tatlong tires na lahat 32psi pero ang gauge nya naging 23psi lang ako kaya ang problema don? Thanks
    Sent from my SM-G920F using Tapatalk
    are we talking of identical tire models?
    baka naman, talagang mas matigas ang rubber nung isang tire?
    but yes, as mina above says, replace your pito.
    Sep 2014
    #22
    Quote Originally Posted by mina_nuka View Post
    Replace your valve core or replace the whole tire valve stem
    Mura lang ba yung tire valve at may size ba yun? Thanks
    Sep 2014
    #23
    ^worse case scenario, may problem yung tire.
    Kelan mo sya binili ang gaano na katagal yang problem?
    Sent from Zenfone 3 on Tsikot mobile app
    Mag 3 years na yung car ko at ngayon ko lang napansin ng mag check ako ng tire pressure.
    #24
    150 bucks and above siguro.
    may imported. may mas imported.
    ang alam ko, for automobile tires, isang size lang. anyway, isang tingin lang sa tire shop, ay alam na nila.
    Sep 2014
    #25
    Yup parehong model lang.
    Sep 2014
    #26
    Safe pa bang gamitin yung tire wala namang singaw yung pito.
    #27
    errr... whypo? is there something inherently wrong with your tire?
    from what i understand, the problem may be the pito and not the tire.
    so, yes! safe.
    Sep 2014
    #28
    so, yes! safe.
    I mean puwede pa bang itakbo yung kotse kahit may problema na yung pito baka kasi magka leak pa yung pito kung hindi ko muna sya palitan
    #29
    *grand kotse
    pwede pa itakbo yan ... basta punta ka na lang tire shop asap
    maganda siguro pa-check mo na lahat ng tires mo ... kasi 3 years mong nakaligtaan
    #30
    my concern is, that pito might be causing erroneous readings, resulting in a vastly over-inflated tire. when used on the road, it might weaken the tire's carcass, resulting in the so-called "oblong". when that happens, the tire would be next-to-useless, as it won't be "comfortable to use", if not dangerous.
    why not use the spare tire in the meantime? bring the questionable tire to the tire shop.
Tire Pressure Question
