Results 11 to 20 of 24
    jan, di nga maganda pagkakadrain nun. i would really suggest you bring it kila chieffy (ronald) para sure.
    ronald, ganyang ganyan din ako. full synth pero pagdating ng mga 6800 kms, nararamdaman ko na di na maganda takbo ng makina, that is why i decided to go back on semi-synth para 5000 kms ulit ang interval.
    jan, di nga maganda pagkakadrain nun. i would really suggest you bring it kila chieffy (ronald) para sure. feeling ko baka kailangan na rin i-flushing yung loob ng makina mo eh.
    Full-Synthetic change ako every 4,000miles (6437.38Km). Sa oil change pinapalitan eh yung Oil Filter and Washer, and of course the oil
    I change oils every 5K kms. Kahit na synthetic oils pa ang ginagamit ko.
    Aug 2003
    question re oil change:
    advisable ba engine oil flush every time you change oil? or drain lang?
    Jul 2003
    same here... fully synth every 5K
    chieffy,
    Ganda ba performance ng HAVOLINE ENERGY? Im planning to have a change oil this weekend. My current engine oil is SHELL SEMI-SYNTHETIC...
    hytan, try mo havoline. tapos determine the difference between what you are using now and energy.
    imho, kanya-kanyang timplada yan. shell's also good, but i had better experiences with havo energy. next change oil ko, i- try ko naman ultron.
    Dec 2002
    Full synth mobil 1 changed every 5-6k km or 6 mons. Also do 1yr interval with mobil 1 on a car that only runs 2-3k km/yr.
    Just a comment on semi-synth: the protection afforded by full synth is from the synth base oil but a semi synth uses a mineral base oil with synth additives. Think you get the same protection from an ordinary mineral oil with high API rating if you change every 5k km.
    The oil filter quality has a huge effect on whether the oil gets cleaned or not, so don't use cheap(generic) gas station filter brands. Stick to OEM or orig Vic and use the right size or part no. Your oil will protect if the filter works as designed.
    dati... ginamit ko mobil1 for 14tkm... then nung drain sabi nung mekaniko maganda padaw oil ko... pag tingin ko nga sa pan nya.... yung akin.. mas transparent pa kesa sa mga ibang itatapon na na oil... yung pinalagay ko sakanya... agip na mineral oil.... panget... hehe... kaya ngayon.. gusto ko sana ipon to buy mobil1 uli... yung 14t ni hindi ako nagpalit ng oil filter.. kahit advised nila na palit ng oil filter... and city driving pa yun... and alot of... u know... park... on makina... that kinda stuff..
synthetic oil change oil interval question/s
