Page 1 of 9 12345 ... LastLast
Results 1 to 10 of 90
    Dec 2015
    Anyone here who is manually maintaining tyre pressure by using gauges and air pumps?
    Aug 2012
    Quote Originally Posted by urbanmetal View Post
    Yes, I do. I have both a tire gauge and a portable automatic digital tire inflator in the car all the time.
    Dec 2015
    Quote Originally Posted by red_one View Post
    for the tyre inflator, do you use your car's battery?
    btw, where did you buy those?
    Feb 2014
    i'm maintaining pressures for 2 cars and 3 bikes. easiest way is to use this foot pump w/ digital gauge. just go to each wheel and use leg power no need to fool around w/ wires and such
    i used to do it w/ a foot pump plus a separate gauge coz i was using a pump w/ an inaccurate gauge. the integrated and accurate gauge on this michelin is a big help. highly recommended
    I used Michelin Micro Tyre Inflator and Coido for tire gauge. Parehas sila ng reading.
    Ginagamit ko yan atleast once a month para maensure ko na tama lagi ang tire pressure.
    (hindi ako marunong maglagay ng picture for reference)
    Dec 2015
    Quote Originally Posted by Vodka View Post
    LIKE!
    How long does it take for you to finish all 4 tyres with this?
    Aug 2012
    Just plug into the car cigarette lighter port. I also have my own AC-DC 12V adapter so I can plug to wall outlet directly.
    D3 Technologies Makati. d3techph in FB.
    Sa tyre inflator, dapat naka-On ang makina para hindi madiskarga ang baterya.
    Feb 2014
    LIKE!
    i top up all my tires every week, sometimes even more often usually 6 pumps per tire.
    Dec 2015
    Need recommendations on the specs of the air pump guys, thanks!
    I guess it would be better if you can recommend tried and tested ones.
Tyre pressure
