Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
    May 2005
    #21
    Quote Originally Posted by fedski View Post
    anu magandang brand ng sparkplug ginagamit nyo?
    lapit nako mag pa tune up
    i currently using bosch super4 (4 tips). nakasanayan lang kya eto parati
    anu pinakakaiba ng 1tip sa 4 tips
    or bosch sa NGK
    car is 97 civic matic
    thanks
    Ako OEM lang, NGK/BOSCH..I clean it once in awhile, pag madumi na masyado e palit na.
    Aug 2004
    #22
    15w - specifies the oil's viscosity at low temperatures. w=winter
    50 - means the oil doesn't thin any more than a 50w oil would at 100 degrees centigrade.
    In regards to most japanese four cylinder engines, which is what we're talking about here:
    From personal experience, as long as the second number is 30 or 40, the oil does fine in tropical weather. 50 is too thick, even on cars which receive 15w from the dealership, it's usually 15w40 only.
    And the first number, 5w-15w work fine on most engines, 15w would be recommended for a high-mileage engine. On newer engines, it feels pretty heavy. With tighter tolerances in new Japanese lumps, most dealerships stick in 5w or 10w oil, and 0w is perfectly acceptable if there's nothing wrong with the engine.
    0w allows the engine to rev more freely, and will actually increase your fuel economy, but if there's any wear on the engine or loose tolerances, it doesn't provide enough protection. Thus, I don't like using it on old cars. For performance engines, though, it's preferred.
    Nov 2003
    #23
    50 is too thick here for most cars. thicker viscosity means worse gas milage pa.
    Aug 2006
    #24
    Thick and thin,The controversial topic never ends.Whatever floats your boat, i guess.
    Aug 2004
    #25
    It really isn't much of a controversy. Almost every gas powered car uses 5, 10 or 15w 40 or 30.
    #26
    I have no problem using 20W-50 on my ride, yung nga lang frequent OC ka, but that wouldn't be a problem anyway. Well as the old adage says,. 5k OC is recommended parin! :D
    OT na bros! ...back to sparkplug na pow!
    *fedski: kahit OE plugs ok na, NGK (BKR6E, I think!?) Denso or Bosch basta correct part#,.. or look for the Cross Reference of this brands.
Sparkplug question
