Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    anu magandang brand ng sparkplug ginagamit nyo?
    lapit nako mag pa tune up
    i currently using bosch super4 (4 tips). nakasanayan lang kya eto parati
    anu pinakakaiba ng 1tip sa 4 tips
    or bosch sa NGK
    car is 97 civic matic
    thanks
    Stick to the manufacturer-recommended plugs.
    No point running hi-po plugs on a non-hi po engine.
    Aug 2004
    If you want to buy fancy plugs, get the platinum version of whatever your stock plug is.
    The benefits of multi-point versus single point is debateable, and it depends on which of the two sits closest to the center of your combustion chamber. Since your engine was designed to run on certain plugs, Multi-point plugs of different heights may or may not work better than stock, and may sometimes be worse.
    Of course, the only sure way to find out is to compare them on a dyno... but that's very expensive. So... stick to stock nalang.
    Niky: hehe, spending 4-5K to test out a product that costs less than 1K ba? :D
    Aug 2004
    Pa-sponsor nalang sa car club... hehehe.
    But honestly, since the Civic is so common, it's possible that you can find dyno results and feedback on Honda boards if you look hard enough. I'm still willing to bet that stock-design platinums are the best.
    Aug 2005
    go NGK platinum or NGK stock
    Nov 2003
    what is more important than how ever many tips it has is the heat range of the plug. it must match your intended use.
    bkr6e-11 na ngk is what we always use on stock hondas
    thanks po sa mga reply...
    mas maganda ba ang NGK compared sa bosch?
    how bout sa engine oil.. anu prefer nyo?
    Jan 2004
    parehas lang sir. depends sa heat range e.
    sa oil, fully synthetic 5W-40 mobil or helix will do.
    dati laging shell helix..
    im planning is castrol GTX.. maganda din ba yun?
Sparkplug question
