Results 1 to 10 of 24
June 8th, 2006 11:21 PM #1
Has any one tried NGK platinum, im planning to have engine tune up at meron kasi akong nakitang NGK platinum P150 ea, maganda ba ito? gamit ko lang kasi regular NGK, any advantage sa regular ngk
June 9th, 2006 01:17 AM #2
it could last longer than the the usual copper plugs. i use bosch platinum, said to last up to 10,000km.
June 9th, 2006 08:54 AM #3
I used the plat version of my BKR6E's before on our Sentra... no difference really and after a while, i switched back to copper plugs since i normally prefer changing every 10,000kms.
It's justa matter of preference on whether you just want to keep the plugs longer or not.
June 10th, 2006 07:01 PM #4
Why don't you try NGK G-Power Platinum?... sa experience before ok siya saken, last longer than the usual,.. umabot saken ng 1 1/2 years (inilipat ko pa sa van namen and the performance is ok parin, no fouling. About less 15k mileage nung pinalitan ko. Around P160-170/plug.
...Just my little 5 cents. :D
Toyota is my choice
- Aug 2005
- 2,063
June 10th, 2006 07:56 PM #5maganda talag NGK or BOSCH. dpende na din kung anong type of engine...
Kpag mahal spark plugs mo sana di faulty engine at wlang singaw vavle seals.. gud luck!
- Jun 2005
- 215
June 11th, 2006 03:48 AM #8I got platinum plugs for almost 5 years now and still going strong. And those are the cheapest platinum plugs that you can bought in the market. MPG is still the same since I replace the plugs and no decline in performance so far.
June 14th, 2006 12:17 AM #9
wow tagal na platinum mo lakay sulit na sulit na yan, NGK g-power platinum ang pinakabit ko. so far ganoon pa rin performance hindi nagbago compare sa regular ,one click start parin, during cruising same din performance all stock kasi engine( only mod grounding wire) siguro makakatipid lang ako dahil sa matagal ang palit ng spark plug insted of every tuneup every year nalang.
Tsikot Member Rank 5
- Nov 2003
- 3,848
