Results 11 to 14 of 14
- Nov 2017
- 242
November 29th, 2017 09:54 PM #11Check your atf level kung ok pa...kung low level na,pwedeng yun ang cause ng loss of power.Hindi ba nagbi-blink ang "d" mo sa dashboard pag natakbo car mo?
Sent from my Redmi Note 4 using Tsikot Forums mobile app
- Nov 2017
- 242
November 29th, 2017 09:59 PM #12Gasoline engine adventure nyo sir?Kung malapit ka sa cavite,andaming mitsubishi servo dun sa sophia sa imus.Sa banawe meron din naman,tyagaan lang at go direct sa surplus shops and not sa mga ahente lang.
November 29th, 2017 10:57 PM #13
Servo is a generic term for an electrical device that has feedback signal as to the last and present position of an electrical actuator like the air blend door of the car's climate control. If you refer to the actuator that controls the engine's idle speed, the technical and proper term is an IACV or idle air control valve..
As per the thread starter's concern, it is called hesitation or stumble most commonly attributed to weak ignition. The available voltage might be too low or there are high voltage leaks in the secondary side of the ignition. The best and fool proof test is the secondary voltage waveform analysis using a digital storage oscilloscope or DSO.Last edited by jick.cejoco; November 29th, 2017 at 11:02 PM.
November 30th, 2017 03:19 AM #14
damn i never used the term dso.. good info
Tesla Philippines
