Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
    Sep 2005
    Quote Originally Posted by v6dreamer View Post
    Better replace it than used the same one. CV joint is one of the most crucial mechanical parts of your car so its a lot wiser to replace besides may tama na yan. Remember, your mechanic must know the torque of your CV joint when he reassembled back in, too tight can damage the halfshaft, too loose will damage it too. If your not sure about your mechanic if he knows about this find out the torque lbs., of your car.
    thanks. question, ano pong brand maganda ipalit sa CVJ and magkano dapat budget?
    May 2007
    Quote Originally Posted by puroy View Post
    Its about $65.00 at the Pep boys or cragen auto parts but, you could find a brand new one at ebay about the same price or lesser.
    it's been over a month now, lumalagutok pa rin new cv joints car ko when accelerating/arangkada. alin kaya problem, yung pagkagawa or ung new replacement cvj's?
    sir may possibility din na sira rubber ng engine support pag may lagutok sa arangkada
    May 2007
    Quote Originally Posted by jolads View Post
    The only way to find out is to check the support. Silipin mo at sabay mong uga-ugahin yon makina. Pag nakita mo mong may biyak palitan na at wag lang yong sira, dapat pair palagi ang palit.
    Sir, can you suggest where I can buy a CV Joint for a nissan pulsar model?as of now wala pako nabibili, it's almost 2 weeks na. Thank you.
    May 2007
    Quote Originally Posted by alord_27 View Post
    Pa rebuilt mo nalang mas mura. Boot lang ang papalitan kung hindi pa sira ang bering. Lilinisin nilang maigi to remove contaminant at irepack nilang mabuti ng grasa at palitan ng bagong boot.
    Nov 2003
    some cv joints can be repacked pero if you wanna play it safe have them replaced na.
    Apr 2005
    update: turned out 1 inner cvj got loose. nire-pack lang lahat. it's been ok since fri.
    Jan 2008
    sir newbie lang po, question lang kasi ganun din problema ko lumalagotok yung front wheel ko at the right side, pero di naman siya tumutunog pag lumiliko ako. minsan lang pag mejo uneven yung daan at sabi ng isang mech ko CV daw dahil punit daw yung boots at puno na ng grasa yung labas niya, CV kaya yun or may iba pang possiblities na mga bushing bushing lang, kasi kakapalit ko lang ng shocks bushing at ball joints
    Jan 2008
    sya nga pala mga chief, ni replace lang mga mga underchasis ko sa evanlgista lang di sa mga kilalang talyer, when i heard this lagatok sound tried to ask for opinion sa mech ng evanglista sabi niya CV daw, i tried 6 other well known underchasis specialist di daw CV possibleng shocks or bushing lang. di ko talaga alam kung san nanggagling yung problema
Replacing C.V. Joint
