Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 48
    Jan 2008
    #31
    Quote Originally Posted by Vodka View Post
    p261 for 5k, no batt included. my 2 small ryobi batts were just given to me w/ worn out cells so i just repacked them w/ genuine Molicel 18650
    dami ko pa kulang i still want the ryobi digital inflator, clip fan, portable fan, brushless cutoff, another small vacuum, SDS drill, brushless chainsaw
    malakas yan sir.. mas malakas pa sa ryobi p261.. shorter motor body since brushless motor na..
    madami na din ako ryobi batts.. pero na replace ko na lahat ng 18650 cells.. bumili ako nung spot welder and around 100pcs na 18650 batts.. kasi yung 5.0Ah eh 10pcs laman na battery.
    i have 3 units nyan ozito brushless.. yung isa comes with socket and carrying case pa.. nabili ko ng 6.5k lang.. hehe
    sa ryobi, i have all these cordless tools.. natutuwa ako sa kulay nya green eh..
    blower
    glue gun
    solder station
    heat gun
    drain auger
    multi tool
    grinder
    reciprocating saw
    impact wrench
    3/8 ratchet
    digital tire inflator with blower
    brushless driver
    brushless drill
    90 degree drill
    vacuum
    orbital sander
    trim router
    work shop led light
    hybrid shop light
    eto pa hanap ko:
    portable fan
    brushless circular saw
    nailer
    sheet cutter
    brushless grinder
    meron seller sa lazada at shopee.. tsaka may isang construction supplier sa calamba ako napuntahan, may mga ryobi sila.. tapos sa corded tools, partner yata ng ryobi ang kyocera..
    ngayon naman, nalipat ang attention ko sa bosch tools.. hehe pero mostly yung 12V tools and corded tool lang binibili ko..
    Feb 2014
    #32
    blower
    glue gun
    solder station
    heat gun
    drain auger
    multi tool
    grinder
    reciprocating saw
    impact wrench
    3/8 ratchet
    brushless driver
    brushless drill
    90 degree drill
    vacuum
    orbital sander
    trim router
    work shop led light
    hybrid shop light
    eto pa hanap ko:
    portable fan
    nailer
    sheet cutter
    brushless grinder
    wow dami ryobis. meron ka din pala spot welder, super useful. here's my re-celled pack. genuine Molicel P26A, dami fakes so i have a verification method (discharge curve matching). you can build up a battery collection for not a lot of money.
    meron din empty battery cases w/ circuit board for around P800. cheap way to get 10-cell packs, 6ah if you use 3000mah cells
    Click image for larger version.
Name:	IMG_20210212_150021 (Medium).jpg
    Apr 2012
    #33
    blower
    glue gun
    solder station
    heat gun
    drain auger
    multi tool
    grinder
    reciprocating saw
    impact wrench
    3/8 ratchet
    brushless driver
    brushless drill
    90 degree drill
    vacuum
    orbital sander
    trim router
    work shop led light
    hybrid shop light
    eto pa hanap ko:
    portable fan
    nailer
    sheet cutter
    brushless grinder
    that's a whole lot of power tools[emoji106] [emoji7]
    #34
    Saw this in FB. Parang mura ito even compared to shopee sellers. Click image for larger version.
    Jan 2008
    #35
    mura yan sir.. kaso maiksi yung hose nyan.. parang 3 meters lang yata.. kaya bumili pa ako ng extension..
    mas ok pang linis ng sasakyan.. sakto sa wheel well yung gun..
    kaso not self priming yan.. alam ko may ibang china brand na self priming na
    Jan 2008
    #36
    yes sir.. sayang kasi.. ang mahal ng battery eh.. although maganda naman stock batt ng ryobi.. LG yata yun eh.. kulay pula..
    kaya instead bumili ng new batt, spot welder binili ko.. tapos gamit ko 8mm strips..
    iba pa din yun factory weld eh.. mas makapal yung strips nila.. kaya dun sa 5.0ah battery, double 8mm strips ginawa ko..
    iba pala lakas pag bago yung 18650 cells.. yung blower ko lakas ng buga ng hangin eh...
    Feb 2014
    #37
    are you using 100% nickel strips? i'm using pure nickel 0.15mm thickness. mas common kasi yung nickel plated steel. an easy way to tell is if it sparks when you weld it's steel
    btw i also use pure copper for high-power applications. for power tools ok na yung pure nickel
Name:	IMG_20210727_105945 (Medium).jpg
    Feb 2014
    #38
Name:	p261 spindle.jpg
    the rear wheel bearings on my City have been running noisy for years now the ryobi P261 had absolutely no trouble removing the spindle nut
    Jan 2008
    #39
    iba talaga pag power tools.. mabilis.. and malakas..
    actually full power yan pag reverse mode.. make sure din na impact rated yung gamit mo na socket.. yung itim.. pag yung makintab nabibiyak yan
    also don't use flower type sockets.. yung maraming points kasi manipis na yun sides at madali mabasag..
    Feb 2014
    #40
    gate repair weekend
    i used MIG welder w/ a small portable co2 tank. if you wanna learn a welding method that'll do pretty much everything, this is it. you can build and repair gates. weld up hitch receivers and nudge bars. you can even build a motorcycle or buggy using MIG.
    TIG is precise but too slow for big metal gates
    the common stick welding is messy smoky and not suitable for thin steel.
    btw it's nice to have a 5" (125mm) grinder (3rd from the left). the common grinder here in PH is the 4" (100mm) which are little discs too small for big projects. the two cordless ones use 4.5" (115mm) discs which are even less common here
    the 5" grinder spins just as fast as a small 4" grinder so the bigger disc cuts/grinds way faster. but use branded discs only coz it could be a bit dangerous
Power Tools
