Results 11 to 20 of 22
January 24th, 2008 04:02 PM #11
- Feb 2007
- 89
January 24th, 2008 07:48 PM #12Baka hindi umandar kasi di nya makokopleto ang 4-stroke cycle nya - opinyon lang :-)
January 25th, 2008 03:40 AM #13
aandar padin naman yan pero aabot ka kaya sa pupuntahan mo.imaginin monalang ang oto mo na flat ang isang gulong.
- Jul 2003
- 573
January 25th, 2008 04:42 AM #14ang original na tanong ay "kung 3 sparkplugs lang ang nakalagay". I believe he is referring to a 4-cyl engine. So there is no sparkplug installed in one of the cylinder, and is left open. In this case there will be no considerable compression or vacuum being made in this particular cylinder. then the engine will still run, but with some noticeable vibration, and reduced power. If it is a carburator type, fuel air mixture of appreciable volume will not be sucked into the cylinder.
you will still be able to drive considerable distance in this mode.
January 25th, 2008 10:03 AM #15
January 26th, 2008 12:15 AM #16
if it's obd2 it will still flag a misfire on that cylinder...why misfire? because there will no crankshaft speed variation on the power stroke of that particular cylinder.
January 26th, 2008 09:36 AM #18
CMP is timed/meshed to CkP to be used to determine valve activity based on piston position and stroke. Without spark, fuel and compression How can there be missfire?
Tsikot Member Rank 5
- Nov 2003
- 3,848
January 27th, 2008 09:56 AM #19if you're not going to put the plug you might as well unhook the injector too.
pero this is a really bad idea in the first place.
January 28th, 2008 06:13 PM #20
Experience ko ito sa 86 model lancer box type, habang tumatakbo biglang namatay ang makina, try ko start ok na ang then pagaandar na namamatay uli ang makina, nag mag check sa makina found out maluwag yung israng high tension wire ng spark plug after reconnecting ito ok na uli ang takbo.
Tesla Philippines
