Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    thanks for the advice... will consider all your suggestions... thanks again...
    Quote Originally Posted by jvdejesus05 View Post
    tanong ko lang po, my in-laws just recently acquired a nissan sentra ss 1993 model, napansin namin nung ginagamit na namin that the water reservoir for the radiator e laging kumukulo yung tubig after using the car... ano po kaya problem nung car and ano po pwede namin gawin? thanks...
    usually kung kumukulo yung radiator mo ... blow by na yung engine mo .....
    check mo kung may tulo ng tubig sa parking spot mo ... kung wala bad news ... overhaul na yan ...
    kung may tulo ng tubig ... water pump ... leaking radiator ... or need to replace your radiator cap or your radiator hose
    another problem is your thermostat mura lang naman orig niyan mga 750 ... or check mo yung mga auxiliary fan mo kung nagautomatic on ba sila if not that is your culprit
    if you like drop by in the shop and let my mechanic take a look
    BANAWE AUTO SUPPLY
    7120115
    regy
    Nov 2003
    the idling and heating problems are different. idling is probably the servo. the cooling system probably a clogged radiator.
need of some advice...
