Page 26 of 41 FirstFirst ... 1622232425262728293036 ... LastLast
Results 251 to 260 of 401
    Mar 2007
    #251
    Quote Originally Posted by spyghost View Post
    Hi,
    I've dismantled my clutch kasi nanikit sya dahil ke ondoy.
    Visuall inspeciton shows na rusted ang surfaces nila, flywheel, disc, pressure plate. The bearing is for replacement na kasi di na umiikot.
    I've taken out the loose rust by sandpaper and blasted it with wd40 and check for flatness by using a steel rule and a light source. Flatness is still ok and surface is relieved from thick rust.
    My clutch is just 10 months old with a mileage of just 15000km. the friction material is still thick. Should I buy another set or can I still reuse the disc and plate?
    WD40 will dry up immediately and rust will set back in.
    If you are nearby - I can share some NewOil with you... I apply this to metal to eliminate friction... but I also apply this to electrical contacts to enhance connections... to my surprise, It can also be used for rubber or friction surfaces where it's needed... for example - fanbelts and even clutch linings.
    If you like your clutch to behave like a racing clutch - use this. Mas maganda maglaro yung bearings and panigurado... walang sliding yung clutch pads mo. I use this in my racing VW bug. Dont use it for brakes... masyadong makapit ito, it will be hard to control your car... I used it with brakes on my mini cooper... umusok yung linings - hindi pala pwede for this area... gusto laging kumakapit. - Wierd but it works!
    For those who have problems with ECU... this might help.
    Pinoy Mega Squirt VEMS-1 (Vehicle Management System).. It can replace your ECU, mas fully controllable pa yung system for your vehicle. Presyong Pinoy pa. the blogsite is in my signature line.
    #252
    Quote Originally Posted by ehnriko View Post
    what's this newoil? where can it be bought?
    Mar 2007
    #253
    It's not in the market... If you need just a few ml. I can just give you some.
    if you need more info... here the site. newoil . blogspot . com
    #254
    it's ehnriko's homebrew miracle oil.
    Mar 2007
    #255
    lol, not really.... really not. The name of the inventor is Danny Soriano.
  6. #256
    hindi nalubog ung innova ko, pero napapaisip lang ako,
    wala kasi ako acts of God pero under warranty pa,
    kung malubog sa baha ung auto ko, covered pa ba yun ng warranty?
    Mar 2007
    #257
    Quote Originally Posted by innoBOB[09JmtG] View Post
    It wont be if it happened last September.... but if that happened in another date where there is no apparent disaster... then it becomes just a normal accident.
    Technically, naaksidenteng napadaan sa baha... so that makes it covered by your comprehensive insurance.
    But flood is a tough item to contend with if used as an excuse with insurance companies.
    Making a really good police report like, the vehicle - landed in a fish pond while it was swerving to avoid a drunk tricycle driver... There has to be an accident of some kind.
  8. #258
    ^yeap, that would be really the one to make up in case. ty
    Sep 2005
    #259
    hindi cover nang warranty yan..
    comprehensive insurance lang dapat yan.. pero kung wala kang AOG.. malabo ka maka claim..
    #260
    Quote Originally Posted by wendellburug View Post
    hello mga tsikoteers..Nalubog din ba BAHA ang Valle verde sa pasig?thanks
    was in my brother's place in valle 2. sampaguita st. (parallel to lanuza ave.) was waist deep in flood water. i heard it was the same in valle 1 also.
NEED ADVISE: Vehicle/Engine submerged in flood water [MERGED]
